Question about Cameras
How do they connect to the camera - Cameras
    Problem Solver:
  • 5 Answers
I presume your question is a typo. Cameras do not connect to cameras, they usually connect to computers to download the photos. The camera shouold have a download cable with a normal USB plug on one end that connects to the computer and a very small plug at the other end that connects into a matching socket somewhere on gthe camera. If you have the camera socket but no cable then either go buy a cable from any computer or camera shop, or you can remove the camera storage card and insert into a computer card reader. It will then act as a new drive and the computer will give it a drive letter. The same will apply if you use a connecting cable between camera and computer. Either way when the computer recognises the camera card, it will give it a drive letter and you can then download your pictures to any folder on your computer. However, almost all digital cameras have download software on the driver disc and if that is the case with your camera then go get the connecting cable - take the camera with you to the shop if you're not sure of the cable type
Dave
Posted on Mar 12, 2011
Wifi conection
This is a computer issue, not a camera one
Apr 01, 2017 | Cameras
What can I try if my Coolpix AW120 won't connect to my smartphone, even if I've followed all steps correctly?
The Smartphone connects to the camera NOT the camera connects to smartphone. You have to have the APP on the camera. You first have to turn on WIFI ON the camera. It is like a server. Then you turn on WIFI on the Phone and connect to the Camera WIFI.
Jul 10, 2014 | Nikon COOLPIX AW120 Waterproof Digital...
My camera says 'Connecting to PC' all the time when I turn it on even if it is not connected to PC. I think it has got confused as the last time I used the camera was to take photos off it and it may have...
Connect the camera to your PC. Turn it on. Wait till the PC 'acknowledges' the camera. Then disconnect it via 'remove USB-device safely'-function.
If this doesn't work. try resetting the camera with the reset button you'll find under the connections hatch.
Jun 14, 2010 | Nikon D40x Digital Camera
Camera won't connect to PC.
Hello!!
install the drivers of the camera again ...
Dec 28, 2007 | Samsung Digimax D53 Digital Camera
"No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
"Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 820 Digital...
"Failed to Connect to Camera." -- Serial connection
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Fun! Digital 320: "Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily rectified: 1.Make sure that the camera power is on. 2.Make sure that the camera cable has not been damaged. 3.Make sure that the camera cable is properly connected to both the camera and the computer. 4.Clean out the computer's Temp file.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
