Question about Sherwood RX-4109
After working perfectly for 2 months, now receiver won't turn on either manually or with remote. Please help,
  • 1,591 Answers
If the unit is that new, it's likely still under warranty. Don't void your warranty, return the unit for repair or replacement!
(if you know the unit is not under warranty, post a reply here, and I will provide possible fixes)
Posted on Mar 12, 2011
  • djwild54 Mar 12, 2011
    Thanks guys!
    Master:
  • 403 Answers
Is it getting power, if so check the manual for an internal fuse. you might have over heated it.
I have a 20.1 Dish remote controller. I would like to use the AUX selection to operate my Denon AV receiver. Can you help me with this?
Depending on the age of your receiver, this may be possible. Turn on the receiver. Then press and hold the Aux button until all of the mode buttons light up. Press 2 to tell the remote that the unit to be controlled is an audio receiver. Then you will need to try one of the Denon 3-digit codes. Press # and check that the mode flashes 3 times. Check if your receiver turns off. If it does, check if the other buttons work to control the receiver. Otherwise try another Denon code by starting at the press and hold the Aux button step.
If you want the remote only to control the volume, mute and power functions of the receiver, press 1 after entering the three-digit code and before pressing the # key.
The Denon device codes to try are 669 670 680 682 696
744 759 760 762 792 809 . You can find the directions for programming the Aux key on page 11-12 of the manual. The code list for audio devices starts on page 43. The manual is available from Dish here: https://www.mydish.com/filestream.ashx?ID=3025 . Usually the code list for universal remote features will not always work with devices that were released less than 6 months before the remote was programmed. Devices released after the remote was programmed are similarly not guaranteed to be supported.
I hope this helps.
Mar 29, 2017 | Denon Televison & Video
Bose av321 video settings won't display on tv
Make sure the video output from your Bose System is connected to the right input source of your tv.If it does not work,try using a different remote control.If it still doesn't work,then you will need the service a Bose repair technician.
Jan 28, 2013 | Bose Av3-2-1 Series Ii Media Center...
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
I have an Onkyo HT-RC230 receiver. Comcast recommends 30135 or 30842 for programming the universal remote (XFINITY DVR 3-Device remote; silver with red OK button). Unfortunately, the first code only turns...
I'm sorry that the codes are not working with the Remote to control Onkyo Receiver. The exact codes are 0135, 0842. Please follow the below steps and use these two codes again and check if that helps.
  • Find the 4-digit code number for your device.
  • Manually turn on the device you are setting the code for (used to verify you have the proper code).
  • Press and release the device key you want to program.
  • Press and hold the "Setup" key until device key blinks twice.
  • Type in the 4-digit code using the number keys.
  • If successful, you will get 2 blinks. If not successful, you get one long blink.
  • Use the remote to operate your device (use Power, Play, etc..)
If the above codes are not working, please try the following codes and check if that helps.
0531 1023 1027 0074 0189 0531
Thanks for understanding. Please let me know the result.
Jul 31, 2011 | Televison & Video
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Bose 321
I have same issue. This happened on 12/31/2007 after 13 months of operation. Though remote is not controlling the unit, it controls TV. I went to BOSE showroom (Chennai, India) and remote worked perfectly with their GS display unit. Then I went to service center. Serviceman promised me to send a CD with software upgrade. Let me wait for a day or 2 receive CD and test it. Have you got any solution.
Dec 28, 2007 | Bose (321GS) System
Old RCA Universal Remote
The remote model number is CRK93J1
you can download the manual at:
http://www.replacementremotes.com/store/downloadpdf.cfm?productid=55977
May 26, 2007 | RCA Universal Remote Control
Sherwood RX-4109 Logo
214 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
