Question about Car Audio & Video
My 98 Honda Prelude stereo needs a code to play and I don't have the manual pls help
    Problem Solver:
  • 14 Answers
90's Hondas require that you remove the radio, find the serial number, and get the 4 digit code from the dealer after proving that you are the legal owner of the car.
Posted on Mar 12, 2011
Need code for 98 prelude
We do not have access to these radio anti-theft codes, you will need to contact the and have the following info, cars VIN and radio serial number.
Apr 26, 2012 | 1998 Honda Prelude
How do i can unlock my stereo forgot the codes?
Unfortunately Honda codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Jun 24, 2010 | Buck Honda Prelude 1999 Car Stereo/radio...
Have 1997 honda prelude w/ honda accoustic feedback system sterio, the anti theft light is blinking and stereo will not turn on to put in code for re-use. dont have manual. disconnected battery and...
first check fuses. check fuse 18(7.5a acc) in the under dash fuse/relay box. then check fuse 46(15a(typesh)10a), and fuse 43(7.5aclockradio) in the under hood fuse/relay box. if all fuses are good then you need to make sure you have 12v on the white/yellow wire(batt) and the white/red wire(ignition) on the blue connecotr on the back of the audio unit(the wht/red wire will only have 12v with the ignition in on or run.
Mar 06, 2010 | 1997 Honda Prelude
I have a 1999 Honda prelude - cd player
You may need to take it to the dealer and see if they can over ride the error. It thinks someone stole it, then after many attempts with the wrong code, it locks up.
Jun 18, 2009 | 2001 Honda Prelude
Fault code 16 auto-transmission honda prelude
you have a problem with the linear solenoid on the trans. it needs to diagd properly to c if its broke, or shorted wire, or disconnected
May 23, 2009 | 1997 Honda Prelude
1989 Honda Civic hard starting and dies for no reason. Cooling fans not working. Trouble codes are #6 coolant, #10 air intake temp, #16 fuel injector. Can anyone lead me to a solution for these problems?
6
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
check your wiring for dirty connections or broken wires, you may have wires that are rubbed through or connectors that are not making full contact. you will need an ohm meter and check wires for continuity. a wiring diagram will be needed.
May 15, 2009 | 1989 Honda Civic
Unlock stereo 2001 honda
there should be an unlock code in the back of your owners manual, or on a card with your vehicl manual
Apr 30, 2009 | Car Audio & Video
I want to install my car stereo but it won't let me because I need a code that I don't have. please help me find the code.
Most higher end car audio dealer/installers will offer a service to reset the anti-theft code program, for a fee.
Aduz
Mar 25, 2009 | Buck Honda Prelude 1999 Car Stereo/radio...
Radio/cd player 2001 honda prelude shows "error."
Look in your owner manuel for a radio code, should be a 5 diget code. If you try to put wrong numbers in the stereo more than three or four times the radio will lock up. If you can't find the code call the dealer with the vin# and they should be able to tell you over thier computer. Another way to find the code is hold number 1 and 6 at the same time for 10 seconds and it will bring up a code that you will have to right down, that code will get your password for your stereo when you call the Honda Dealer. If your stereo does lock up just take your battery cables off and hold the red and black one together for 30 seconds and this will reset your radio.
Feb 16, 2009 | 2001 Honda Prelude
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
