Question about Apple iPod classic MP3 Player
I have an ipod classic which keeps crashing my pc it has a file .metadata_never_index which I cant get rid of which I think is the problem I deleted it off my ipod and then did a complete wipe of my pc but no change!! HELP
    Master:
  • 178 Answers
It may be a bad file or malware format the device
Posted on Mar 12, 2011
I need a registration code for snipping tool found at softonic.com
iPod Data Recovery is a data recovery utility that can restore your lost music, videos, pictures and others that have been deleted from your iPod.This application is also able to support all versions of iPo (iPod Mini, iPod Shuffle, iPod Nano, iPod Classic, and others). It is able to retrieve data from 8 GB to 64 GB even if your iPod is inaccessible or if you receive error messages such as "iPods Crashed", "Re-formatted iPod.Ipod data recovery software to recover all your documents, songs, video files, podcasts, e-books, and graphic files lost due to accidental deletion or formatting of iPod.For Free trail
iPod Recovery Software for Windows
Jan 23, 2014 | Computers & Internet
IPod Classic 3rd party manager
http://www.mediamonkey.com/product_ipod.htm This is a good Alternative to Itunes.
You can keep all your music on the Ipod and delete from the Hard drive.
Dec 27, 2007 | Audio Players & Recorders
How does one manually delete a file on an iPod Classic 80GB?
Virus attack can cause this problem. If you want to recover your lost files, you can try 4Card Recovery.
Jan 07, 2014 | Apple iPod classic MP3 Player
Deleting Files
You must select the files you want to delete through itunes then synce to the device.
SHOCKWAVE
Try deleting the FarmVille app. Next install the app again. If it keeps crashing after that then I reccomend maybe deleting some apps. My iPhone did the same exact thing. After I deleted some apps it has not crashed since. If deleting some apps also does not work then you possibly your iPhone is getting old. My iPod had that same exact problem last year. I got a new iPod and the app have never crashed. I hope this helps!
Apr 16, 2013 | Zynga FarmVille by Zynga
Cant unlock volume on i pod 160gb classic
unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Feb 04, 2010 | Apple iPod classic MP3 Player
I dropped my ipod classic 80 gb. It can't be detected when i sync to my computer. I did a hard restart but it it says that my files will be deleted when i restore it with itunes. I dont wanna lose my files...
The only way to save the files is by connecting it to pc and storing them in a file. Try checking the usb connection inside the ipod. If there are any broken wires or solder joints, re-solder them or anything you can do to get it to connect.
Try connecting it, go to control panel, the ipod should be able to found on the I: drive.
Jul 20, 2009 | Apple iPod classic MP3 Player
Unlocking the volume control on 80G Classic ipod
Heres how to unlock the volume control, Don't listen to music to loudly. It will destroy your hearing.
open my computer and then
  1. Enable hidden folders.
    Go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". I honestly do not know how to do this on a mac. I'm simply stupid.
  2. Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Apr 19, 2008 | Apple iPod classic MP3 Player
Creative zen 16gb
If your cpu will read your zen, you can delete files by going to ZEN media explorer. If youre cpu will NOT read youre zen, find the fix for it at another FixYa.
Feb 13, 2008 | Creative Labs Zen Digital Media Player
I pod shuffle
hi ya,
Well firstly to use any Apple iPod products you need iTunes, which you can download form [http://www.apple.com/itunes/download/] for free if you don't already have it installed
once you have this installed, check this article form apple its great, will get you on the why to be a iPod guru ;)
http://www.apple.com/support/itunes/windows/tutorial/index.html
Have fun
Z33m
Dec 10, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod classic MP3 Player Logo
108 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
