Question about CORTEX DMIX-300 Mixing Deck For iPod, MP3 player, CD drive , USB storage devices
When i plug the power source my dmix 300 only blinks and it doesnt stay on. what can i do to reset the dmix or what can i do?
There maybe a short in the wire, try using another wire with the same rating and it should power on. If not then it maybe a defect with the product.
Posted on Nov 24, 2011
  • CORTEX Master
  • 5,603 Answers
It sounds like the power connector is NOT making solid contact, but only toches briefly as you insert connector. Often these connectors have problems if the size if the pin vs the hole in the connector is not compatible. The OTHER common problem is that the solder where the connector attaches to the circuit board breaks loose. When you insert the connector, the broken solder joint briefly touches and cause the unit to blink and then the connection breaks again. Open unit and assess the connection.
One other common problem is the cord breaks at the flex point where it is molded into the connector. as you move it, it can breifly touch inside the insulation and then seperate again.
Posted on Mar 12, 2011
Yamaha Stagepas 300
short.. main out mosfets are damaged.
Sep 09, 2014 | Yamaha STAGEPAS 300 Portable PA System...
When turned on, it blinks and everything stays lit. doesnt turn off either.
To turn it off you need to VERY quickly press the power button and get off it... If you hold the button it will stay on.
Sep 21, 2011 | Sabine Z1000 Zoid Clip On Tuner
Hi. My boss br 1600 will n ot start. I turn on the power source and it will blink for a split second and then nothing. I checked for loose connections but everything seems ok. Any suggestions?
I have this problem with mine. I've did some research and with the boss br 600 this problem can arise quite often .it's caused by a faulty power diode apparently except in that case I've never heard ofrom the screen blinking at all (which my 1600 also does) I wonder I'd this problem can be the same for a br 600 as the br 600
Sep 08, 2011 | Boss BR 1600 Cd Br1600 Cd 16 Track Digital...
Hi, I have a cortex DJ Mix 300 but only some of the songs on my ipod are being picked up on the database when I load it up. It doesn't seem to make a difference whether the files are MPEG or other...
There are different digital formats and some are not compatible to transfer file names... It is frustrating isn't it?... run into this all the time. To fix the probllem you would probablly have to buy a music editing software packaage that you could edit the files and put them all in the compatible mode.
Aug 06, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
My Cortex Dmix 300 has automatically turned autocue on so everytime I load a track on to play it immediately cues up at the first point of sound. Any attempts to re-cue the track just takes it back to the...
hmm there must be a button w a secondary function for the auto cue. if not are you using software with it. check there as well. if you cant find it let me know ill do some research for ya.
May 11, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
Occasionally at power up, all the channel signal indicators will flash simultaneously on and off, staying lit for random lengths of time, there will be slightly more noise coming from the main outputs of...
Make sure you are using balanced lines, especially to the power amps. ALSO make sure ALL interconnected equipment is powered from the SAME receptacle or source, even if it means running extension to where the amps are powered. Ground loops are a pain and can cause serious damage to your equipment.
Jan 12, 2011 | Mackie cfx20 mkII compact mixer
Studiophile AV20 left speaker doesnt work when connected. its passive, and does function when plugged to another power source. Right speaker cannot support left, or any volume above mid setting, and burns...
Probably NOT a transformer. Most likely in the power amp. Many have a thermal cutout that shuts the thing down when the chip/stick gets to hot. Your description leaves some questions... IF you don't get anything at all out of the left, then look first for a short from the amp to the output jack. This probably has a dual chip amp in it and half that chip may be bad heating up and shutting the whole thing down.
Jan 01, 2011 | M-Audio Avid Maudio 99005226600...
NO LIGHT OR SOUND
A BARE USB cable should NOT have caused any problem. If it was an "Active" type cable that does a conversion something might have happened. Another possibility is you had a static charge on you and the static did damage. Another possibility is if the connector really wasn't the SAME type and pins were shorted. Turn off the power and with a bright light compare the connectors to see if this last possibility might be the case. Also look for signs of arcing or bent pins. If the connector was forced, then it is possible the circuit board was cracked.. In any event servicing is required.
Search the web for a "Factory Reset" sequence for the unit. Usually you have to hold a button or a combination as you turn power on.
Jan 16, 2010 | Pioneer DJm 400 Professional DJ Mixer
CORTEX DMIX-300 Mixing Deck For iPod, MP3 player, CD drive , USB storage devices Logo
121 people viewed this question
Top CORTEX Music Experts
Vito Vacirca Jr.
Are you a CORTEX Music Expert? Answer questions, earn points and help others
