Question about Samsung Computers & Internet
I have LCD monitor Samsung 225BW. When I turn on my computer I have to wait 30 minutes to get the picture on monitor.
    Master:
  • 178 Answers
You should update your motherboard drivers
Posted on Mar 12, 2011
Monitor will not come on. Power light just flashes.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 13, 2010 | Samsung 225BW Monitor
Any one have the list of caps that need to be repalced
You can get a full repair guide with parts list at:
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
There is also a video showing how to dis-assemble the unit to get to the power supply board.
I hope this helps, if so please rate my solution.
Jun 25, 2010 | Samsung 225BW LCD Monitor
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
Need to replace all capacitors in my 225BW. Need
The 225BW monitor uses the same capacitor kit that the 214T monitor uses. You can order the repair kit at:
http://www.ccl-la.com/LCDrepair4.htm The kits run $12 including shipping. If you don't want to do the repair we do offer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 31, 2010 | Samsung 225BW LCD Monitor
Samsung syncmaster 225bw 22'' when turned on has a white screen after about3 min i sut it off in the back of the screen for about a min it came back on like nothing was wrong. what is the problem.
This is a symptom indicating the power supply is about to fail. We have a step by step repair guide posted on our web site at: www.ccl-la.com Th repair will require replacing 5 small parts that will need to be soldered on the board. If you don't want to do the repair yourself we do offer a repair service for this model for $30 plus return shipping. If you have any questions contact us at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Jan 08, 2010 | Samsung 225BW LCD Monitor
Prior to this past week my Samsung SyncMaster 225BW monitor's display came on almost instantly when turned on. Now it takes at least 30 seconds to reach full brightness. What is the most likely cause ...
kmzwolski, NO, NO, NO!!!! Do NOT wait. Use your warranty NOW!!! Do not let them off the hook. Could be any of the things you mentioned, plus "cold", intermittant solder joint, thermally/vibration fracture of solder joint on printed circuit board (SMPS/inverter circuit) Let me know how you fair with SAMSUNG. lmistyrel on aim.com or 12fixlouie on fixya.
Dec 16, 2009 | Samsung Computers & Internet
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
NOT TURNING ON
The Samsung 225BW has a known issue with the backlight power supply going out. The dark screen with no power light or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Apr 05, 2009 | Samsung 225BW Monitor
Samsung model 225bw does not turn on
The Samsung 225BW has a known issue with the power supply going out. The dark screen with no power light or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Computers & Internet Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
