I have a dell dps-1200EB 12 volt smps. I am trying to increase the voltage to about 14 volts. I cant seem to locate the regulator or the reference to it, usually a resistor you can change value to change available voltage. I have 3 hours of inspection of the insides so I am pretty well aclimated to the supply. Any help would be great, a schematic would be incredible. Thank you
  • 3 more comments
  • colinsouney Mar 12, 2011
    dps-1200eb is the part number. switched mode power supply.capable of 12 volts at 100 amps of available current. It does work as a stand alone unit, so I should be able to increase the voltage, if even only a volt maybe more. I understand there will be a loss of available current.
    DPS-1200EB 12v 100 amp switched mode redundant power supply. Where can I get the schematic?
  • colinsouney Mar 13, 2011
    Thank you for the honest and direct answer. Is there a practical way to lower the voltage? I have a somewhat unlimited supply of these and can run them in series. 12 volts at any current is not as important to me as no more than 18 volts at limited current. 14 volts nominal would be spectacular. Again I can get these for just about scrap value, so the education of the modification would go huge bounds for my shack, thanks.
    I am not concerned with the wattage, while Im sure it will still be reasonable at a higher voltage. I do not have a hipot tester. I have an unlimited supply of these and if I can figure out how to manipulate the voltage, I can use them in my shack.
    Even 13.8 would be acceptable. The issue is that I have a variety of ham transceivers, the output transistors in them do not really come to life untill 14 volts. The difference between 12 and 14 volts is amazingly different. I cant get more than 30 watts out of my daily rig untill there is emission issues. At 14 volts I get over 50 watts before I run into issues. These of course are RMS readings. Currently I have 4 variable linear 50 amp astron supplies running in parrallel and set at 15 volts. Thats a lot of realestate compared to these nice little switchers. Thank you for all your help.
  • 4,889 Answers
The regulation circuit comprises of a 3 pin voltage regulator . Look for an IC with number that looks xsomething like LS 7xxx. Get me the number and I will verify if you got it!
Posted on Mar 13, 2011
  • 1,555 Answers
In case you are trying to increase the voltage without changing the wattage. You shall let me know that do you have any potmeter in there. Further, I kindly need to know that what type of transformer that unit is having.
  • 12,061 Answers
Hi, you cannot simply alter the 12V Voltage, it is NOT as simple as changing a resistor.
The entire SMPSU design is around 12 V & 5V & 3V, it isn't realistically possible to alter the 12V to 14v under any circumstances, sorry.
You would be best to simply construct, obtain a power supply that provides 14V and "Piggy Back" it onto the existing supplies 230V input.
www.smpstech.com/
Have a look at the website above it show one how to design SMPSU's
Posted on Mar 12, 2011
  • electronic & computer repair&  servicre
    hi, I forgot to add also, you see the secondary windings of the main, Flyback/Buck/Boost transformer, are limited to a MAXIMUM of 13.8V AC & 7.2V AC, to get any more voltage out of the Transformers, and these ARE the limiting factor, you would need to overwind it, IE: Add extra turns to the transformer, to produce an increase of the Voltage output, and this isn't really possible.
    Hi again, I see the desirability of wanting to use a supplies like you have got. you MAY be able to up the Voltage to about 13.8 V, to do this you would have to somehow adjust the feedback circuit, and lessen the Voltage going back to the regulator IC, this in turn, MAY cause the regulator to drive the switching transistors harder, and MAY increase the output? You need to get a spec sheet on the IC's used to control the SMPS.
    Also perhaps whatever you need to operate WILL actually work, @ 12V? as, usually a thing works on a VA rating or Watts, a function of Voltage and Current, now if you have 100Amps or so, then the Voltage may be able to drop somewhat yet STILL have the, Current, the OOmph to drive the device, it may just be worth a try, it definitely cannot hurt.
  • 1,536 Answers
One common design for transformer-isolated smps uses a three-terminal voltage reference on the secondary side to drive the opto-coupler LED for the main regulator. This controls the 5-volt supply, and the 12 volt output is set by from this by the turns ratio of the transformer (i.e, 12/5 of 5 volts). If you find the voltage reference, you can download the data sheet and figure out how the ratio between the 5 volt output level and the voltage reference controls the feedback LED current. Once you have this, change a resistor to get 5.8 volts and your 12 Volt supply should go up to 14 volts. Other designs use a Zener diode and an op amp. In any case, the reference is most likely in the 5 Volt feedback opto-coupler drive circuit. There is also a reference in the primary side switching regulator driver, but this is designed to measure the current through the opto-coupler output transistor and modification here would be more difficult to carry out successfully.
Note: there are probably over-voltage protection circuits that will shut down the supply if it goes outside the limits for its usual application (5.5 V, 13 V). Generally these use zener diodes as independent references; you can change the zener diode (or, if the zener voltage goes through a voltage divider to the shutdown circuit, change a resistor in the divider) to raise the over-voltage limit.
There are SMPS automobile battery substitute units on the market made for powering car stereos on the workbench. They put out 13.6 Volts and may be easier to use for your application. However, one of these takes more cash and is probably less fun that what you're doing.
    Brigadier General:
  • 3,513 Answers
Hi
Increasing voltage is not only a bios level function, Its the bios and the chipset.You can increase Voltage by software. The bios is programmed for the chip therefore the voltage levels will be in that program and chipset also dependant on the bios.
It is suggested to contact dell customer care to get a proper guidance.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
Aug 16, 2015 | 2001 Ford Expedition
How do I test to see if my alternator is bad? The dashboard lights: Gas, batt, and brake light all came on randomly. Theyll go off at 2500 RPM and my volt meter reads somewhere in the 9 volts range.
9 volts isn't enough my friend. You need about 14 to14.5 at a fast idle. Get a hand held automotive volt meter/tester and put the two clips on the two battery posts. Read the voltage without the engine running. Then start up and read the voltage at 2500 rpm. If the voltage is 12-13 at idle and 14 or so at 2500 then the gauge is faulty. If the volts are barely different to the static voltage or lower then the alternator is basically dead. The vehicle systems may play up when the volts fall below a certain level. I can't comment on the 02 sensor but that may be an independent fault. Some alternators have replaceable brushes or regulators complete with brushes. If you are handy with tools download some info on swapping the brushes/regulator or consult the workshop manual because the brushes are a few bucks and half an hour to change. If the alt has done a high mileage there will be wear on other components, bearings etc and a replacement would be a better long term bet. Check out your local parts store or go online to a Japanese auto spares site.
May 02, 2015 | 1993 Isuzu Trooper
How many volts I have a charger that has different volts which one to set it on I have a whistler 1610 just trying to put the charger on the right voltage
Most automotive electronics work on a 12 Volt DC system. You must be using adapter capable of providing about 12 to 14 volts because car batteries provide 12 volts; but car alternators put out 13.8 volts. Do not attempt to connect to an adapter that put out AC voltage!
May 21, 2014 | De-1610 Radar Detector With Car Charger
I have a 01 flht the has a problem with the voltage or charging system the bike volt gauge sits around 11 volts at idle but when driving the bike around 2 thousand rpm the volt gauge reads at 14 volts the...
Sounds close.
The faster the engine's RPMs, the faster the alternator spins, causing the voltage to increase.
The voltage regulator (as the name implies), regulates the voltage coming from the alternator, and going into the electrical system.
Factory instrument gauges are not alway accurate, and more so just gives you a rough idea of what is going on.
A better test is to get a DC voltmeter, and connect to the battery terminals and see what's going on.
At idle, should be about 11-12-13 volts.
When the engine is reved, it should never go above 14-15 volts.
Apr 26, 2014 | Motorcycles
What or how does the battery get its charge
Most bike have an alternator driven off the left-hand crankshaft shaft.
This turns with the engine, producing the AC charging power.
This power then runs through a voltage regulator, that both converts the the AC voltage into DC voltage, and regulates the amount of voltage flowing into the remaining electrical system.
Now, you did do the first step correctly.
DC volt meter to battery terminals to see if you get 13-14 volts DC with engine running.
Next, locate voltage regulator and unplug connector for wires coming FROM the regulator, and hook up the DC voltmeter.
With engine running, you should have 13-14 (or so) DC volts.
If not, locate and unplug wires coming from alternator to regulator, and hook up AC (note change from DC to AC) voltmeter.
With engine running, should have AC voltage (this could be 20-40 volts or more).
This will let you know where the problem is, and what needs to be replaced.
Apr 25, 2014 | 1993 kawasaki KLE 500
Voltage regulator
In some brand of alternators the regulator and brushes are an integral part and it is a matter of removing 2 screws and lifting out the part. On others the regulator is entirely separate unit located some where else on the vehicle. The voltage of 15.3 is on the upper end of the charge rate but it would be acceptable . Nominal voltage for a regulator is 14.5 to 15.5 volts. Understand that a battery is actually 13.2 volts not 12 volts and you need 14 volts for the battery to charge effectively. The higher the voltage the higher the amperage to run everything so if your alternator regulator is set at 14.5 volts then the max amps of the alternator would not be reached and if you have a current draw to run everything that is more than the output of the alternator then the battery will eventually go flat. Find yourself a reputable auto electrician and discuss the problem with him not a local mechanic
Dec 16, 2013 | Dodge Grand Caravan Cars & Trucks
Battery wont charge, battery/ABS/SRS/BRAKE lights come on while driving and flicker. voltage increases to dash lights/fan speed/headlights periodically.
Get a volt meter, start your car and see how many volts your car is producing while running. Should be around 14 volts. May want to watch the meter for a while since your electric seems to fluctuate. Most voltage regulators are internal of your alternator. If you are getting a lot more or less than 14 volts while running, replace the alternator. If it is not charging, voltage will drop as vehicle runs, until battery is dead.
Dec 12, 2013 | Cars & Trucks
Battery draws down during ride. volt meter reads only 9 volts. all other electric systems seem to be ok except one insterment light seems to be out (tach light) Is this likly to be an alternator output...
when running at bat use good vom 14 + volts .good bat volts non running 12.6 v .if not check wire to reg ..check that reg is grounded GOOD , bat in good shape ..them check for good assending voltage at stator plug. use ac setting on vom. 0-150 v will increase w/ rpms do not leave unplugged to long just to test..smell primary oil should not smell burnt I often replace reg & stator together.. harleytalking.com
Oct 19, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Kawasaki vn2000 not charging how do you test system
voltage from stator or alternator is measured in AC volts after it passes through the voltage regulator it is measured in DC volts.the volts at low rpms should be around 12 and go up to 14 or so when rpms are increased. not sure what proper AC volts should be (mine are aprox. 45-50)at isolated stator wires,they are not measured against ground but against one-another
Mar 27, 2010 | 2000 kawasaki VN 2000
Pinouts for DPS 1200 eb a /24 pin
CALL A LOCAL COMPUTER CABLING SPECAILIST AND SEE IF THEY CAN HELP YOU WITH THE PIN OUT
NEED MORE HELP CONTACT ME
CANDYMANGANDY
Jan 28, 2009 | Dell (DPS-1200EB) (F5323) 1200-Watt Power...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
