Question about Kenmore 22422 Top Load Washer
Kenmore 110 washer
Actually is a kenmore 110 model toploader, cold water flow is minimal to none, hot water ok.. Filter, valve, blockage
  • john shollenberger Aug 05, 2008
    I have an old 110 washer and no water comes out when the setting is on hot or warm. When it is on cold a very small flow will come out. If I turn off the water supply then turn it back on the water flows normally until the next cycle.
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Have you unscrewed the cold waater hose and cleaned the blockage from the screen there?
    Genius:
  • 1,028 Answers
If screens on both ends of cold fill hose are clean replaced valve have seen restricted flow even with good flow to valve but be sure screen in valve is pulled and cleaned be sure to reinstall it
Posted on Aug 01, 2008
Kenmore washer water not filling
there is a inline mesh filter at the tap end of the hose but it is more that likely that the tap washer need replacing
it is possible that the inlet solenoid valve is not operating properly
if you have separate hot and cold water hoses and taps then either tap should produce a full flow when set if no taps get a full slow when selected , indicates a problem power board
Nov 05, 2017 | Kenmore Washing Machines
Kenmore heavy duty 80 model 110. rinse cycle at cold is down to a trickle, and seems to be lessening. Takes hour plus for a full water load if mixed alright flow for warm and hot
Your cold water line is clogged, kinked or the water valve solenoid is not opening all the way. First check the hose, then the screen on the valve for clogs. If none then replace the water valve assembly.
Dec 15, 2010 | Kenmore Washing Machines
Cold water just trickles in. Water flow up to the
Hello, this is going to be a problem with your inlet valve, First thing to do is remove the inlet hoses from the valve and check the filter screen on both the hot and cold for debris blocking the water coming into the machine. If this is clear then your going to have a blockage inside the valve. Since these valves are factory sealed your not going to be able to clear the blockage, you should replace the valve. Hope this helps...Thanks for using fixya!!! Good Luck!! Mike
Aug 02, 2009 | Kenmore Washing Machines
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Cold water no flow on Kenmore front load washer
Check cold hose to see if it is clogged or the filter in the end of it is. Make sure water freely coming out from the tap. If that is all ok then replace the watter control valve on the cold side.
Dec 31, 2008 | Kenmore 43142 Front Load Washer
Washer produces Hot Water Only
first be sure you are getting a good flow of cold as far as the washer connection..if so ck inside washer connection for a small wire screen be sure it's not plugged if so clean and flish line to remove anything inside hose ..be sure to put screen back in ..if still no cold suspect bad cold section of valve..replace valve..last remote possibility temp switch is bad
Sep 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore 110.92274100 Rear Panel Access - Cold Water Problem
the top panel comes off via 2 screws that hold control panel on
once this done yuo can lift the whole hob and front and side panel to expose the workings
the cold water valve has a filter inside the water entry so to check this just take off the hose to the machine and look inside hole
if this is ok then you may need to replace water inlet valves
i presume you have high pressure water if not buy valve that is for low water pressure
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 22422 Top Load Washer Logo
319 people viewed this question
Sal De
fordexpert
Robert Rankin
