Question about Acer Computers & Internet
I have Acer V193HQ LCD monitor, there are floatings moving from bottom to up, i tried to adjust the clock, but still it is appearing, please suggest me.
  • Sara Whitfield
    Sara Whitfield Mar 12, 2011
    What do you mean by floatings? If your icons on the desktop are floating, while on you desktop right click on your mouse and it should give the option to stay still.
4 Suggested Answers
SOURCE: Moving line in LCD monitor
Just change the 4 capacitor near of the regulator area of the power supply...
that will fix your problem
Posted on Aug 03, 2008
bammbammfran
  • 159 Answers
SOURCE: Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Posted on Oct 11, 2008
avcstereo1
  • 143 Answers
SOURCE: Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Posted on Jun 11, 2009
Screen sethi, i am using HP LP2065 LCD with my computer. Now the problem is that color setting of LCD is not good and hence no clear picture and video.Please suggest me what i should do. thanks
try in menu auto adjustment and factory reset......
you can also play with frequency a little and color setup , clock and clock phase in Image control menu, play with it and you will see result... then save it...
Mar 27, 2014 | HP LP2065 Monitor
My acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msg are shown but once Windows starts, this error appears. I have tried to adjust the...
May I ask to what you mean by "adjust the resolution in safe mode, this has not helped"?
Did you set it to native resolution of this monitor? Unless it has problem inside the monitor, try it with another PC also.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 08, 2010 | Acer AL1916W 19" LCD Monitor
I bought acer v193hq 8months back. now the screen is broken. what should i do can i claim warranty what will it cost me
From the Acer web site: "Cracked LCD displays are not covered under the normal warranties and should be serviced through our out-of-warranty process."
I would suggest you just buy another LCD. I recently bought one, new, on sale for less than $100.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 04, 2010 | Acer Computers & Internet
My acer Model X221WSD monitor screen is pink. I've tried
Pinkish back ground can be the sign of the lamps are going bad, but usually it will also cause the screen to go into shutdown mode also. Try New VGA cable or move the VGA connectors? Does the same on other PC?
Please post back so we can guide you further toi narrow down the problem.
http://www.badcaps.net
Apr 09, 2010 | Acer Monitor Lcd 19in Al1923 0.29mm...
Hi There! My Acer x223w monitor is floating a "Input Not Supported" box that will not go away any suggestions?
The documentation for this monitor should list its supported resolutions, and you will need to attach another monitor that supports a greater (possibly lower or higher) range of resolutions and then set it to one of the supported resolutions for the monitor. The native resolution appears to be 1680x1050, although I cannot find online documentation directly from Acer.
May 04, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Jan 02, 2009 | Acer X193W LCD Monitor
'Input Format Not Supported' (please help me!)
OK try booting up in "Safe Mode" Press F8 just after Turn on, when and if ya boot into safe mode then adjust your Video settings to say 1024x768x32bit and then reboot, if all good then when you are at the desktop, then adjust the settings to whatever you require... maybe 1280x1024x32bit.. Ya all good. If this doesn't work.. try the Monitor on another PC.. see if it works... if it does.. then maybe ya Video card is going/gone "Toes up" if not, then ya got a fault in your monitor, usually some sort of Power Supply problem or the like.
Jul 23, 2007 | Acer AL1916B 19" LCD Monitor
Computers & Internet Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
