Question about Motorola Mobility RAZR V3
Razor freezes When I close my razor insted of my background coming up the T stays there ( the T is supposed to be there when the phone is open i have T-mobile) then when i open it back up it freezes a fter a couple of seconds it will either go back to normal then a few seconds later the screen will turn off and the key pad will stay on or the phone it will just turn off and when i try to turn back on the screen stays off but the key pad will stay on i have to turn it off and on a few times just to get the screen tp turn and then it just does the same thing. Any ideas why its doing this?
  • 1,586 Answers
Hate to say it, but your phone is on the way to its death. I've had two RAZRs die on me, and both showed similar symptoms before they went down. It's a combination of the ribbon wire that connects the screen to the keypad half of the phone (causing the power problems) and the open/close sensor on the phone not realizing you've shut the phone (which is why it's keeping the T up on the screen). If you have warranty coverage on it, move all your contacts to your SIM card, send any pics you want to keep to your email address with mms messages, and then go show them the problems. They should give you a new phone.
Posted on Aug 01, 2008
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
How i clean my razor
I have this razor as well. Just flip the heads open, dump the hairs in the garbage and rinse the heads (while open) under hot water. Keep the heads open until dry and close on up.
May 20, 2009 | Norelco Arcitec Electric Shaver -...
Screen is not working; previous water damage. Phone not been same
For the symptoms your are giving, probably the best solution is to get a new phone. Sorry about that
Apr 09, 2009 | T-Mobile Motorola Razor V3 Custom Cell...
Phone freeze
try taking your battery out for a little while. then if it freezes again...just keep taking it out for a few minutes...it worked once on my razr.....good luck!
Nov 15, 2008 | Motorola Mobility RAZR V3
Razor phone srceen goes blank after a few seconds
This is the Early signs of Failure! Just had to Upgrade my RAZR for the same Problem. Your Options are (1) Have it Repaired-Costs a LOT! (2) Upgrade to a New or Refurbed Razr. There are no other Solutions
Aug 09, 2008 | Motorola Mobility RAZR V3
Razor V3
Take it to the service center, the keyboard cable got broken or worn.
May 03, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Feb 01, 2008 | Motorola Mobility RAZR V3
Razor is frozen up
u need new key pad ribbon might be ic on board http://www.mobilephoneservicecentre.co.uk/
Jun 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
