Question about GT Interactive Beavis and Butthead: Bunghole in One for Windows
Game comes up saying Golf.exe has encountered a problem. What can i do to sort this
A black screen appears on my computer when i open nfs prostreet
To all the fellas that have a problem with running Pro Street on Windows 7 or Vista.(you know the black screen upon starting the game) It doesnt matter which build of windows 7,vista you Have. the sollution to this is to go to program files or which ever localtion you installed the game. Rename the "nfs.exe" to "nfsps.exe" and go to the Pro Street Icon on your desktop, right click and click properties. go to the target path and edit the "nfs.exe" to "nfsps.exe"
e.g: "C:\Program Files\EA games\nfsps.exe". Please note that this may not be the same target path as yours depending on which path you have installed the game.
Click apply and ok. then run the game.
note: this fix is only for gamers that encounter a black screen when starting the game in windows 7.
Jul 28, 2011 | EA - Electronic Arts Need For Speed:...
I just bought and installed pipemania by empire interactive on my son's pc. every time he tries to play the game we get an error message saying "pipemania has encountered a problem and needs to...
You should try going to directory where the game is installed and find the .exe file that starts the game. Right click on it and find compatibility tab and change there to win 98.
May 04, 2011 | Computers & Internet
At start up application error message is displayed saying that the application explorer.exe has encountered an errorand must shut down. help?
press F8 on bootup and start it in safe mode with network, if that doesn't work its a restore, unless you know a man who can copy the offending corrupt file and replace it, but safe mode might just sort it. you never stated what operating system you are using but try it anyway.
Feb 01, 2011 | Sylvania G-Netbook
7 Sins for Windows: I have purchased the game 7 Sins. I am running wi...
this is all i can find at mo..
I think the problem you are having is related to your computer hardware configuration . .
But you can do something to achieve better gaming experience . .
Go to the game icon e.g. 7sins.exe
Right click on it and Click on Run as an Administrator.
Say Yes or OK to the next screen.
And you can play it without inconvenience . .
But this is not a permanent solution ..
For a permanent solution . . you need to upgrade your RAM so that it may process the game more smoothly..
or try this link out.
error The7Sins Retail exe has encountered problem and needs to close We...
Oct 29, 2017 | Atari 7 Sins for Windows
Try installing Sims2 on my comp. Had the game a couple of years ago on my computer but uninstalled it. Computer is XP version. when I put the disk in a box comes up and says Eletronic Arts has encounted...
Hi teri,
try this
  1. put the disk in
  2. let it do its thing and tell you autorun is broken
  3. open up "My Computer"
  4. right click on the driver the sims cd is in
  5. on the drop down menu select explore
  6. when the cd directory comes up find the setup file and double click it.
  7. have fun playing sims.
If there is another error after this please mention it and ill help you get through it.
Nov 12, 2008 | Computers & Internet
Exe
Right click on its .exe file and goto compatability mode > select "Run in 640*480 Resolution" , "Disable visual themes ", "Disable desktop composition", "Disabe display scaling ..." and give it a try ..........this will resolve the issue if not you don't have the proper hardware requirement for the game.......also don't use internet while you play.....turn off the adsl.......
Sep 26, 2008 | ASUS P5PE-VM Motherboard
I installed need for speed pro street and when i try to play something comes up and says nfs.exe has encountered a problem and needs to close.
Okay. Can you verify how much RAM is installed? You will find that info in the system properties (Start/ and right-clicking on My Computer/Properties). The game needs 2 gb of RAM.
Aug 26, 2008 | Computers & Internet
Csi game error
go to the Quick time web site and download the newest version 7.5.5 or higher
Jun 18, 2008 | Video Game Consoles & Games
Wii super swing golf
it's usually a symptom of a bad disk, in you cause i would say bad game.
Dec 28, 2007 | Nintendo Wii Console
GT Interactive Beavis and Butthead: Bunghole in One for Windows Logo
62 people viewed this question
Top GT Interactive Video Game Consoles & Games Experts
James Wishart
Are you a GT Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
