Question about Craftsman Air Tools & Compressors
What type of bolts hold the plastic motor housing together on a craftsman pancake air compressor. 6 gal. model# 919.153160. I can't see down in the hole to see what type it is
  • 10,865 Answers
Hello jerry.... go to searspartsdirect.com, enter your model number and you will see the bolts and be able to order them if u desire. Joe
Thanks for choosing Fixya!
Posted on Mar 12, 2011
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
3 Gal, Craftsman Air Compressor. Builds pressure to about 20 psi, no further. While it was running, it bogged down and sounded different. I felt around the entire compressor for any leak, but only found...
It sounds to me like the motor is shot, Bogging down at 20psi makes me suspect the brushes are gone. No good contact on the brushes or even just a bad connection of the power cord will cause it to heat up and lose power under load. Check for worn or lose power connection first, then see if the motor brushes are replaceable. The brushes would be under a screw type cap on the motor with a spring holding the actual brush in contact. You will have more than one so give it good look over.
Mar 04, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
I have a 6 gal, 150 psi craftsman compressor. There is a leak under the plastic housing. How do I seperate the tank from the compressor?
This product manual will show the exploded view on how it comes apart/goes together:
http://c.shld.net/assets/own/00915216e.pdf
Jan 06, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Air Tools & Compressors Logo
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
