Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Whirpool refrigerator ,water dips into the fridge compartment from the freezer
Hi
I am trying to clean the drain tube.After removing the cover to access evaporator.I saw drain hole underneath coil but drian hole is covered with plastic cap.I tried to remove it but could not.could u please help me to remove pastic cap from drain hole.
Thanks
Manan
  • jatindermana Aug 01, 2008
    What is it. How can i clean the clogged tube.Warm water is sufficient to clean it
Drain tube location on Whirlpool frig??
Posted on Jan 23, 2009
  • 828 Answers
It is not supposed to be removed. try flushing some warm water through it.
Posted on Aug 01, 2008
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
The top freezer compartment drain hole ices over and freezes up and then the moisture goes down into the refrigerator and accumulates under the crisper drawers. This is a frost free fridge.
Hi and welcome to FixYa. I am Kelly.
The compartment drain is most likely clogged somewhere other than the funnel in the freezer compartment. Often what happens is the very end of the drain tube in the very bottom of the unit at the drip pan gets coated with lint and gunk. It then dries off and makes the perfect PLUG. Here is what I recommend you do:
1. Unplug the unit and do a manual defrost by directing an external fan into the freezer compartment for just over 2 hours with the contents removed. It takes this long because the water in the drain funnel acts as an ice insulator and you have to get it above 33F.
2. While the manual defrost is in progress remove the fiberboard rear panel and access the drip pan. Make sure the very end of the compartment drain is cleaned off. Clean out the drip pan also. These can get very nasty.
3. At the end of the 2 hour manual defrosting period... use a vacuum on exhaust and direct air into the RND of the compartment drain tube. Your trying to float out and debris from the drain funnel in the freezer compartment. Have someone listen for air-flow in the freezer from the ddrain funnel if possible.
4. Reinstall the rear cover and return the unit to normal service.
This works most of the time. However if there is a pinch or a kink in the compartment drain tube somewhere the problem can easily repeat.
Thanks for choosing FixYa,
Kelly
Jul 02, 2011 | Refrigerators
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Water accumulates under the vegtable and fruit bin
You may have a pluged drain tube and prevents the water from draining into the drip pan below the fridge.you will have to remove the tube from rear of fridge and clean.If you cannot get into the tube you will need to remove the rear panel inside the freezer compartment.and then pour hot water down from there till it breakes free.If your freezer is iced up you wil need 1of3 things first defrost timer second defrost thermostat third defrost element.Hope i helped:)
May 18, 2009 | GE J Series 20.6 cu. ft. Top Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
259 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
