Question about Craftsman 3000 PSI 27 GPM Briggs Stratton Powered Pressure Washer
WIULL NOT PICK UP SOAP FROM CONTAINER - Craftsman 3000 PSI 27 GPM Briggs Stratton Powered Pressure Washer
    Problem Solver:
  • 13 Answers
There could be a block in the syphon hose going from the soap reservior to the sprayer. Take the hose off and blow through it to make sure the the hose is clear. If the hose has a scrren/filter on it make sur that is clean also. Where the hose attaches to the sprayer make sure the orifice is clean and not plugger up with scum or other debri.
Posted on Mar 17, 2011
Hotpoint soap drawer leaking, wfooo
The problem is not a leaking soap container. The problem is that it is overflowing because the line from it to the washer tub is clogged. This happens mostly when using powdered detergents. Check you operating instructions for soap dispenser cleaning procedures.
Jan 03, 2015 | Hotpoint Washing Machines
Tip
How to Make Tattoo Inks Out of Ashes
<a href="http://i.ehow.com/images/a07/fk/pq/make-tattoo-inks-out-ashes-800X800.jpg"> <span><img src="clip_image001.jpg" /></span></a> <br /> <b>Instructions</b> <b>ThingsYou'll Need:</b> <ul> <li>1 cup ashes </li> <li>Blender </li> <li>Vodka </li> <li>Airtight container </li> <li>Clean towel </li> <li>Soap </li></ul> <ol> <li>1</li></ol> Clean yourstorage container. Wash the container with soap, hot water and a sponge. Drythe container with a freshly washed towel. <ol> <li>2</li></ol> Pour theashes into the blender. Add about 1 tbsp. vodka. <ol> <li>3</li></ol> Blend theashes at a medium speed for about 1 hour. <ol> <li>4</li></ol> Examinethe mixture. It should be the consistency of slush. If it is too thick, addabout 1 tsp. vodka and blend for another 10 minutes. If it is too thin, addabout 1/4 cup ashes. <ol> <li>5</li></ol> Pour thetattoo ink into the clean storage container. Press the lid to the container sothat it is airtight. Store the ink in a dark place or use it immediately.
on Jan 28, 2011 | Air Tools & Compressors
Kranzle electric washer will not suck up soap
Hi, if it has a chemical injector on the machine then the pressure at the lance will have to be lowered for it to pull in soap. it works on a similar principle to how carburetors on cars pull in fuel, bernouli principle. high pressure at one side of an orifice going to low pressure at the other side which causes a negative pressure ( vacuum) which should pull in the soap. there should be a non return valve at the orifice (hole) which prevents the water back feeding into the soap container, it is quite common for this valve to get stuck, it is just a ball, spring and o ring , and the ball sticks to the o ring. if it is this system then take the soap pick up pipe off the injector and just push the ball off it's seat with a bit of wire.
If it is a high pressure soap system then that is different, but they usually work with an injector in my experience.
try taking the high pressure hose off the front off the machine and running it, if it has an injector on it it should pull in plenty off soap.
hope this helps ,
andy
Oct 12, 2013 | Electric Kranzle Professional 1600 PSI...
Pressure Washer Troy Bilt 2700 PSI 2.3 GPM will not pick up soap. I am using the black tip low pressure head and it still does not pick up the detergent. Any recommendations?
Take the small soap line off and make sure you can blow air through. Where the line attaches to the soap container make sure the hole is clear if not take a streight pin and make sure the pin goes in the hole easily.
Mar 14, 2011 | Garden
Dishs have soap flim
If your dishwasher has been in use for a period of time, you may need to clean the interior of the washer.
The next time you are at the grocery store, pick up (2) containers of "Tang" orange drink. With no dishes in the dish washer, fill the soap container with Tang, close the lid and poor the remaining Tang in the bottom of the dishwasher.
Close the door and run through your regular wash cycle. You may have to repeat this with the second container if it is an older model washer.
The citric acid in the Tang will clean the soap scum off the inside as well as the pump chamber inside the washer.
Good luck, it worked for me, cleaned it nice and shinny and smells good too.
Regards,
Aug 13, 2009 | Dishwashers
Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Whirpool washer fabric softener container
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Mar 08, 2009 | Whirlpool AWM8143 Front Load Washer
Have the Kenmore Limited Edition dishwasher, model # 665.15892100. When dishwasher is running, you can hear the soap container flip open. However, @ end of washer's completion, and main door is opened, the...
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Feb 02, 2008 | Dishwashers
Dishwasher soap container spring is broken
I too thought my soap container spring was broken- I filled the dispenser with soap but then couldn't slide the circle back shut.
But then - EUREKA- I set the dishwasher control back into "off" position and lo and behold, I could now close the little round door! Make sure you verify that BEFORE you spend $$$ on new parts or a repairman!
Sep 18, 2007 | Dishwashers
Craftsman 3000 PSI  27 GPM Briggs  Stratton Powered Pressure Washer Logo
481 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
