Question about Danze Sheridan Tub & Shower Faucet
The Fairmont has no apparent way to remove the handle to permit replacement of the cartriodge. How?
  • Paul Beyer
    Paul Beyer Mar 12, 2011
    Need the model number
  • 86 Answers
They either have a small cap on front to pop off then screw under cap..or they have under or to side of handle a very tiny set screw recessed...it is a allen screw...loosen and pull out...
Posted on May 22, 2014
Switch for roller brush not working and brush not going round, any help plz?
mikerobin143 's solution
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
http://i471.photobucket.com/albums/rr74/NinjaRider08/Dyson_DC15.jpg
Nov 01, 2010 | Dyson DC15 All Floors - The Ball Bagless...
External door handle is floppy and does'nt work
you wil have to pull the trim panel off hte inside to see if the fasteners are loose or the pivot is broken.
The trim panel mostly pulls off with spring clips after a couple of screws are removed. Pry at clips with a screwdriver.
Aug 28, 2010 | 1983 Ford Fairmont
How do you fix a dripping shower faucet? It is not leaking from the hot or cold handles, but the spout itself.
if it is an old fashioned valve then there are cone washers in the valves that control on and off
they are fairly easy and cheap to replace
Jan 11, 2010 | Danze D316440RBT Fairmont Two Handle Wall...
Head gaskit need replacing.how...
You have either a one-of-a-kind car or you are wrong on the year or model. Fairmont didn't extend beyond 1983.
If you have no experience working on engines, I recommend you buy the Haynes manual for the car:
1978-83 Fairmont
Oct 20, 2009 | 1983 Ford Fairmont
I want to remove my Amana Refrigerator handles
The handles are probably attached with screws from the back -- this will require removing some panel(s) to access them.
Apr 29, 2009 | Amana ARS266ZBS Side by Side Refrigerator
How do you remove the areator from a danze bathroom faucet
They usually just screw off counter clockwise. You may have to purchase a special wrench that has a plastic protective cover so you can grip it to remove it. Or you can try using a towel with a pair of pliers to remove it.
Apr 10, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Danze shower fixture issue
If it is a single handle there should be an access hole to the under side of the handle that will allow access to a allen style set screw, loosen it and the handle can be removed.
Feb 21, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
How to you get the cap off the shower handle/
try a magnet before drilling if it don't work drill a small hole do not push in to screw
Cannot get the cap off the shower handle of a Danze fixture
not familiar with that exact unit but alot of the caps unscrew or pop out when pried or you may have set screw on body
Ford xd door handles
order a chiltons repair manual for $19.95 from
autozone or any other parts store.
Jun 12, 2008 | 1983 Ford Fairmont
Danze Sheridan Tub & Shower Faucet Logo
75 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
