Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model # PPS25MGNAWW GE PROFILE ARTICA -when opening therefrigerator door -there is a beeping noise and the lights on the cooling display blink and go out. The cooling and freezing seem to be working fine however the icemaker produces ice but sometimes doesn't want to dispense it. Thx!
    Brigadier General:
  • 3,513 Answers
Its very difficult to suggest one single solution for this as there are couple of reasons for the issue. I would rather request you to check out this article which includes the reasons and troubleshooting steps for the same:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=222860&PROD_SUB_ID=0&PROD_ID=823
Please let us know if you need any further clarification.
Thanks
Posted on Mar 12, 2011
How to get the light to come on in the freezer side by side ge profile artica?
Open the door. The door switch should pop out, the light should come on. If the bulb is burnt out, that would hinder the process. If the bulb is good, I would start with checking voltage at the receptacle and work backwards thru the door switch until I found where the power was lost.
Sep 01, 2016 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica no display
I would inspect the wires that are located at the bottom left freezer hinge, opening and closing tends to break the wires over time. crimp the broken wires into a sleeve type connector, there will be little to no slack to use wire nuts. If the wires are perfect, you might need a new display board, but the wires are the prime suspect...
May 02, 2016 | GE Profile PSI23SGR Arctica¿...
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng...
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Display out
Does the display not light up when you press a button ?? Check the electrical connector at the bottom of the door as it may have corroded or become disconnected.
Sep 01, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica won't drop temp past 52 degrees
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
YOU NEED SERVICE FOR THIS PROBLEM!! SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Aug 26, 2008 | GE Profile PFS22 33" Artica French Door...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica
The main PCB at the back of the appliance has failed
Nov 12, 2007 | GE PSS25NGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
44 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
