Question about Acer AL1717 17" LCD Monitor
I cant turn on my 15" lcd monitor AL1717 A - Acer AL1717 17" LCD Monitor
  • 11,361 Answers
Look for bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1717Abm/
Make sure to replace them in a set with low ESR type 105c caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 16, 2011
  • 1,591 Answers
First, check the power cord is tight in the monitor, and in the outlet or power bar. If it's in a power bar, make sure the power bar is turned on and doesn't have a tripped breaker.
If that all looks good, then there's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 12, 2011
  • Acer Master
  • 6,771 Answers
This is a very common problem with the monitors, the Acer has a power supply problem, often caused by bad capacitors that sometimes bulge at the top indicating they are open. I have found that one bad capacitor on the power supply board will shut it down. The unit will need to be dis-assembled carefully to access the board and the parts replaced.
4 Suggested Answers
tantong
  • 138 Answers
SOURCE: LCD Monitor needs repair
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what is the problem of your LCD monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. You don't need to do anything with the inverter board in this case. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
firesnake09
  • 2923 Answers
SOURCE: LCD Monitor Acer AL1717 shtting down problem
Aside from the capacitor and IC, there's a relay that you need to change. You need to locate that defective relay on the PCB and replace it.
It would be best to consult the manufacturer of the LCD and get the exact part number of it.
Have a great day!
Regards,
Firesnake09
Posted on Apr 26, 2009
chiplevel
  • 656 Answers
SOURCE: my lcd monitor AL1717 has
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Posted on Apr 01, 2011
How do I turn on the Acer AL1717 speakers?
the internal speakers, RTM it tells you how.
you plug them in to the PC, audio part conn.
then unmute the audio.
then up the volume.
also RTM the monitor OSD may have speaker enable , selection.
that is it.
Sep 26, 2013 | Acer 17" AL1717 Flat Panel Color LCD...
How do I fix the "shadows" on my Acer monitor?
Try the monitor on another system to see if the monitor or the video card in the computer is the cause, replace the appropriate parts.
Aug 31, 2012 | Acer AL1717 17" LCD Monitor
Why does it take so long to see my desktop icons when I power on my Acer AL1717 monitor?
bsellers, Tell me in "seconds", "minutes", how long is "so long". Do you even see the "boot screen" pop-up when booting the pc? You should see that first if lcd monitor is turned on first. Are you running a Windows OS? Will a "known-good" VGA monitor work ok when connected to your PC?? Will your AL1717 do same thing when connected to different "known-good" PC?? Did you even look at the "date of manufacture" on the rear of your monitor? Retrevo .com lists 1717 as time to retire??? Was your unit produced in "06" or "07"?? Let me know results of doing some simple "swap-out" tests. 12fixlouie
Dec 15, 2010 | Acer AL1717 17" LCD Monitor
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
Acer AL1717 lcd plss help
Your resoulutions are Hz are too high in the game settings for your monitor. Reinstall your game.
Jan 08, 2010 | Acer AL1717 17" LCD Monitor
Need to turn off internal audio on flat screen to use headset
When you plug in a headset or mic into the bottom or the side of the monitor, this should automaticly disable the internal speakers on the monitor.
May 26, 2009 | Acer AL1717 17" LCD Monitor
Black lines in Acer AL1717
On the power supply PCB are two 25V 220uf capacitors that will be leading. Replace them and the picture should be back to normal.
Dec 28, 2008 | Acer AL1717 17" LCD Monitor
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
