Question about Dishwashers
I keep noticing black ash like residue all over the dishes in my cabinet, today I noticed it on the dishes in the strainer next to the sink. I'm not sure if its the water or from the heater.
  • Dishwashers Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 14, 2011
How to remove and replace dishwasher?
Turn off the circuit breaker for the dishwasher power and shutoff the hot water supply (usually located under the sink). Next take off the lower bottom front cover to access the electrical connection and water supply line. Remove the cover to the electrical connection and disconnect the wiring. Pull the supply wire out of the connection box. Next loosen the connection for the water supply line. Have a towel handy to soak up the residual in the water line. Disconnect the drain hose from under the sink. It is either connected to the garbage or to a tee above the sink drain trap. Loosen the clamp and remove the drain hose. Again you'll need that towel to soak up the water from the drain hose.
Most dish washer are attached to the bottom of the counter top above the top of the d/w door with screws. Remove these screws. You may also need to loosen the leveling feet located on the bottom of the d/w at the front in order to pull it out.
Now you can remove the D/W from under the counter top.
Be sure to keep the drain hose on top of the D/W while pulling it out to keep the residual water from draining onto the floor.
Be sure to secure the electric supply wire with wire connectors after the D/W is removed for safety. Also cover the drain connection at the sink or disposal with duct tape to prevent sink water draining into the bottom of the sink cabinet.
Nov 19, 2017 | Dishwashers
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Sink erator
First, unplug the power cord to the "Sink aerator" disposal from under the sink storage area. Next, remove the black rubber strainer from the upper sink area leading down into the disposal. (It simply pulls upward to remove) This will allow you to put your hand down into the disposal area to physically clean out the disposal deposits by hand. Pull out whatever is plugging the disposal and throw the debris in the trash, not back into the disposal. Once everything is removed from inside the disposal, flush it out completely with water from the faucet until it drains freely. Reassemble the black rubber strainer and plug in the disposal once clean. Be sure not to put potatoe peelings and other non-disposable items which can't be ground up easily in the garbage disposal. Keep in mind, just because it says garbage disposal, it doesn't mean all "garbage." Also, always use plenty of water when using the disposal and allow the water to run for a minute or so afterwards to finish washing down the debris in the sink "P" trap drain out through the outer sewer line.
Jul 07, 2014 | Home
Dishes constantly come out dirty.. What temp should the water be while the dishwasher is running?
Supply water temperature should be above 120 degrees F for effective cleaning. Run hot water from your kitchen sink (your dishwasher should be tapped off the hot water line near your sink faucet) right before you start a dishwashing cycle to make sure it's as hot as it can be when the dishwasher begins filling. Also, during the wash cycle the heating elements at the bottom of the tub may turn on and warm the water further even if you select a "No Heat Dry" option causing a noticeable shot of steam to escape if you open the door during a cycle.
Note: I recently had a problem with our dishwasher (Frigidaire FDB834RFS0) causing dishes to come out dirty and the detergent dispenser to be left with undissolved detergent. Our problem happened to be caused by a partially clogged strainer in the water supply valve. (I would imagine Whirlpool most likely has some kind of filter/strainer in its water valve as well.) When the supply valve was commanded to open for some time, I noticed the water level in the tub would barely be visible below the lower spray arm. After cleaning out the strainer (required removing and disassembling the water supply valve) the water level was noticeably higher -- almost at the bottom of the float or about an inch below the heating elements. Our dishes and the detergent dispenser are now clean.
If your water supply is ok, I would next check to make sure your spray arms do not have any plugged holes and that they rotate freely. Also, use a good quality detergent and a rinse aid. We prefer liquid Cascade and Jet Dry. We have had problems with old, stale, or really thick liquid detergents and by getting a fresh jug have solved the dirty dish dilemma.
Make sure to clean out the filter basket at the bottom of the basin below the lower spray arm occasionally as it can clog and cause the pump to starve due to lack of water. If the pump can't get a supply of water to pump to the spray arms and nozzles, your dishes will not get sprayed evenly and you will end up with them being poorly cleaned.
Hope this helps you out...good luck!
Nov 18, 2010 | Whirlpool Dishwashers
Maytag dishwasher Model # DWC4910AAW SN A9830611KY Doesn't clean dishes anymore...leaves white soap (Cascade) residue on all; doesn't clean dishes anymore.
msbcox -- Check for residue in the strainer under the lower washbar. Remove the lower dish rack. Strainer is under washbar. Sounds like it is not draining properly. Write back if you need more help. -- SWT
Aug 04, 2010 | Maytag Dishwashers
No water going into dishwasher checked supply line its good Frigidaire model fdb635rfr6
Just had a similar problem with my Frigidaire FDB834RFS0 model. Dishes were not getting clean. Noticed some detergent still remaining in the dispenser after completing a wash cycle. Checked the water level during several cycles and noticed it was barely visible in the bottom of the tub. Decided to remove the water supply valve and solenoid to check it, thinking I would probably have to buy another one. Took it apart and found there is a mesh water strainer on the inlet side that was full of bits of junk. Cleaned it out and decided to reinstall to see if it made a difference. Noticed immediately when starting the next cycle that I could hear the water gushing into the tub. The water level rose significantly and the result was clean dishes and no left over detergent in the dispenser.
Jul 31, 2010 | Frigidaire Dishwashers
Dish washer does not drain water
Hi
The drain is clogged. Check the strainer at the bottom of your unit. Always rinse your dishes of food before putting them in the washer.
look under the sink cabinet,do you see the drain hose from the D/W? that hose needs to be routed all the way up to the bottomside of the counter top then back down to the disposal. you may need to set a screw into the underside of cabinet and a small piece of wire to hang the hose ,this will solve the problem
Thanks for contacting Fixya.com
Oct 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
