Question about Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME
I have installed a Tuscany Brass single handle tub & shower faucet. When the faucet is turned on, water comes out of the shower head. Also, the water is only luke warm. When reading the manual to find out how to adjust, the directions and illustrations do not resemble this particular model at all.
I have the same problem. Have you heard a solution?
Posted on May 02, 2011
    Scholar:
  • 82 Answers
I have been searching the Internet for solutions to my problem which is that I get no hot water from my LDR Tuscany Brass Anti-scald, Pressure Balance Single Handle Tub and Shower Valve. I've determined that my manual does not match my valve exactly but I've been able to extract the cartridge and look at the insides. This valve was never in active use since installation so there was no mineral build-up. But a couple of years ago, our city mistakenly turned off our water shut-off valve in the street while trying to find a leak. Rust and particulates came rushing through our water supply pipes and contaminated almost every faucet we have so I think something might have happened to this valve at that time. Does anyone know if those screws on each side of the center of the valve are truly just "stop valves" and might be clogged up throwing off the balancing mechanism?
Posted on Oct 08, 2013
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
New shower valve installed but can only get cold water seems to be an issue with a small cartridge inside the control
Nov 19, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
When i turn on single handle faucet for shower i get water coming out of spout and shower head at same time
The insert that houses the piston for the water to travel in certain directions is not located or position in the correct manner
Jan 23, 2010 | Moen & One Handle Tub & Shower Faucet
Delta T13090 faucet shower head working at the same time.
The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
Turn the water off to the house.
Use an allen key to remove the handle.
Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
Reassemble & Enjoy!
Aug 05, 2009 | Delta & Single Handle Shower Faucet
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME Logo
1,653 people viewed this question
Top Ldr Industries Home Experts
Donni Steen
Tom Chichester
Are you a Ldr Industries Home Expert? Answer questions, earn points and help others
