I have a problem ,I need a motor and a pump to spray with moskitos mist away nozzles water on the hvac and i need a motor to work 5 to six hours continiusly.
  • 2,071 Answers
How to check vacuum leak to hvac
use a spray bottle filled with water
spray a mist of water over the area where you suspect a leak while the vehicle is idling
if there is a vacuum leak the idle speed will rise and drop
Aug 17, 2016 | 2006 Pontiac G6
Aeg oko favorit 50500w water not coming in through spray arms
There are several reasons if spray arms doesn't spray water. First you need to check efficiency of circulation pump. If it works, then should check the turbine of circulation pump. Sometimes turbine blades can be broken and the pump does not produce enough pressure to turn the spray arms. Be sure to check that the filter is not clogged which can also causes same problem. Finally, check that the nozzles of spray arms are not clogged.
So, could be:
- motor circulation pump
- circulation pump
- filter
- spray arms
- electronic or power board
Dado
Jul 12, 2014 | AEG Dishwashers
It is full of kerosene however when I plug it in to start, it will not turn on. It makes the effort for about two or three seconds then turns off
The safety is turning it off because it is not lighting. You did not mention if it was actually trying to light, or if it was just the motor running. If it is not lighting, take the top cover off and watch the ignitor. Depending on the type of ignitor, it will either glow or spark when you plug the heater in. This should happen before the fan starts running. Once the fan starts, you should be able to see a mist of fuel coming out of the nozzle. If there is no fuel spray you may have an air pump problem, which is on the back of the motor, or the fuel screen in the tank may be plugged.
1. Check for ignition source
2. Blower motor should start, if you have ignition
3. Fuel should spray out of nozzle, if not check filter and check for air flow out of the pump.
4. If you do not have any air flow, or not enough air flow check the pump. Pressure out is critical.
5. If pressure is too low check for leaks around the pump. Spray soapy water on the back side of the motor/pump housing. The plastic pump cover is bad about cracking, and the cracks are very hard to see. The plastic cover could also be loose on the pump.
6. While on this end of the pump; the filters need to be clean, as they will affect the pump pressure and upset the whole apple cart.
Jan 18, 2011 | Reddy Heater-30-55,000 BTU Variable
Poping burner smokeing
These are quite simple heaters to go over start with your fuel. Is it clean? Is there water in it? Is your fuel filter clean? After verifying all is good lets take off the top cover and check things out. Is the nozzle spraying a fine mist or heavy droplets? The mist should be very fine, nozzles are not supposed to be cleaned out but I have found that first the screen in the nozzle assembly can corrode so clean it up then you can try carb-cleaner and a tooth pick and gently clean the nozzle, replacing it is the recommended practice, pay attention to the spray angle and the GPH rating if you replace it. It is a fuel related problem I assure you but while you have the top off clean up the electronic eye that senses the flame and the igniter as they build carbon deposits.
Dec 13, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Burner nozzle selection for Kerosene torpedo heater
Hello Teisco I would go with semi-solid style Spray pattern is not related to ignition.Universal is probably semi-sloid but stay away from that one.Spray pattern relates to running combustion noise,style can make all the differance.A.50 nozzle can&will clog easily ,replace it and dont touch/change anything else.See if thats it.Pump pressure should NOT have changed but is 100PSI.spark gap, stick near 3/8 or less.If it lights & sputters out dont change the gap .Is there water in the fuel?
Jul 26, 2010 | Heating & Cooling
Have a Bissell Proheat2 will not spray water from the carpet power head but sprays from tools setting Does anyone know how to get water to spray or clean out water
I had this problem. It was small pieces of debris that got into the solution lines and clogged all the nozzles. There is a nozzle for the handheld attachments, one on the front of the machine for spraying spots and two nozzles underneath just behind the rotating brushes.
It was a royal pain disconnecting the clear rubber hoses inside the machine and blowing out the nozzles and the hoses with compressed air. If you are mechanically challenged I'd suggest you take the machine to a vacuum/steam cleaner repair facility.
I'm not sure how the debris got into the solution system, but it may have been when the dirty water tank was emptied some of the dirty water entered the internal, clean water bladder.
A note to Bissell engineers: This issue can be prevented if you simply add an easily accessable solution and/or water filter that the customers can remove, clean and reinstall. Just a suggestion.
Apr 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Windshiels washer worked yesterday but not to
Check for airlock on pump input (if pump not mounted below water tank level),
check water delivery at pump outup port is ok,
check for kinked/crushed delivery hose,
check for blocked squirter nozzles.
Oct 17, 2009 | 1999 Isuzu Rodeo
Water nozzle sprays only with thin jet of water-water will not fan out.
CLR
BUY SOME CLEAN OUT THE HEAD REINSTALL HEAD USE AS PREFERED
also check you are ajusting the head right
failing that buy a new head
Jul 27, 2009 | Karcher Garden
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
