Question about Samsung Refrigerators
Icemaker makes only crushed ice - Samsung Refrigerators
    Guru:
  • 1,524 Answers
Pull your ice bin out and look at the opening where the brass colored rod enters. There is a solenoid inside the housing that should actuate to move the bucket arm in order to dispense cubes. Stick your finger in there and see if you can get it to drop down. The solenoid may be damaged, or just frozen in place. Once it drops down and with the freezer door open, actuate the door switch with your finger, while pressing the ice lever in the dispenser. Make sure you have selected cube and crushed first. The solenoid if it is working will snap up then fall back down when you release the lever. If it doesn't, then you will need to remove the housing it is in and see if it is full of frost. The solenoid shaft must move freely in order to work properly. They will rust with time and become pitted preventing proper operation.
Posted on Mar 12, 2011
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Jul 06, 2009 | Frigidaire FRS23H7CS Side by Side...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Samsung refrigerator RS267LABP icemaker
it could that your thermostat is set too cold making the ice crack and brittle
Mar 18, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
WE HAVE A GE REFRIGERATOR THAT IS ONE YR OLD AND IT WILL NOT CRUSH ICE. WE'VE REPLACED THE ICE MAKER AND IT STILL WILL NOT CRUSH. IS THE SOLENOID OUT BEHIND THE ICEMAKER ARM IN THE FRIG WALL? GE MODEL...
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Feb 03, 2009 | Refrigerators
Ice maker in door not making ice
make sure the switch is turned on on the icemaker if it is then see if there is water in the icemaker it could be either water valve or icemaker
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working no water getting to icemaker
Icemaker is making ice slowly. Crushed ice button does work.
Aug 25, 2008 | Refrigerators
GHE monogram ice maker.
pull the icemaker out, say be one inch, shack it a bit, and jam it back in. We've done that each time we had that problem, before it started to work. The icemaker is designed poorly, my openion, and gets jammed easily each time you use the crushed ice. crushed ice jams the ice crusher, and cloggs the pathway resulting a no ice dispensing situation. Also try using only whole ice cubes, instead of the crushed ice. the less you use the crusher the less you'll have to problem. one last thing. if the ice is sitting in the basket for a while, due to poor ice despensor opening door design, the ice in the basket cloggs together causing the probelm.
May 19, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
420 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
