Question about TC Electronic TC Helicon VoiceLive Touch Portable Vocal Effects Processor
I want to buy a voicelive touch from the states,what do i need to do to make it work on australian 240 volt power
  • TC Electronic Master
  • 5,603 Answers
Check your pwer adapter as MANY of them will take 100 to 240 volts inout... if yours does, you are go to go... else here is one that will work as it is a worldwide type:
http://lcdpayless.com/productpage.php?productId=6679
Posted on Mar 12, 2011
VoiceLive
I had this problem. I sprayed the switches with contact cleaner from outside and jiggled them a bit. I also powered it from a different socket. The problem has not recurred since.
Oct 22, 2017 | TC Electronic TC Helicon VoiceLive Touch...
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
So the wattage of the is 32 watts and voltage is 12.8v. is it?
This makes no sense... 32 Watts and 12.8 volts... something to do with this speaker that is rated at 500 Watts???
If you are trying to calculate something for a car amp you don't understand how they work... that is the only thing I can think given the 12.8 volt thing you stated. Most high power car amps BOOST the incoming battery voltage up with a switching power supply. For instance, they might boost to 48 volts and that applied to a 4 ohm speaker would be 12 amps PEAK maximums. BUT the RMS power is one half that or about 288 Watts in round figures before considering losses.
Many car amps are designed to run with 2 ohm speakers... JUST SO THEY CAN CLAIM massive power values in their ads so you will buy them!
Jan 21, 2011 | Peavey SP2 PA Passive Speaker
I cant plug my 120v input vamp2 power adapter into a 110v output voltage regulator its dont works
I don't understand why you are plugging this into a 110 volt regulator.. If by chance you are trying to run this from 220 volt power, you DO NOT use a regulator or a converter intended to run hair driers and appliances. You need to use a step-down transformer from 220 to 110 or 240 to 120.
The V\Amp2 is a switching regulator and it will NOT like to be run from another switching regulator such as found in those cheap appliance type convertors.
Here is the type you need: http://www.world-import.com/tc-100a.htm
Jan 07, 2011 | Behringer VAmp 2 Power Supply
I am thinking of buying a yamaha dd-65 portable digital drum from America. But I live in Sydney, Australia so am assuming I can't use it here (because of the different voltages)? If I were to buy the...
If you use the right adapter for the voltages it will work fine. The other option is to use a transformer that steps the power down to 110 to 120 and use the supplied adapter. The unit takes very little power.
Jan 04, 2011 | Yamaha DD65 Portable Digital Drums
I have a Roland AC60 amplifier that I brought from Australia to the US. The Australian version of this amp runs on 240 volts not 110. My question is; 1) does anyone know if converting this amp to...
The only simple way that I could think of is for you to purchase a STEP DOWN TRANSFORMER rated at 500 watt, 110 volts, 60cycle. The transformer inside that amplifier have four output 12v and 15v DC.2amps It will be hard to get the transformer for that! Hope that might help you! taah!
Nov 18, 2010 | Roland Ac60 Acoustic Chorus Guitar...
Europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Feb 05, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
It is a 230 volt, I want to convert it to 120 volt. D I have to change the transformer or can I rewire the current setup.
If you can find a schematic that will answer your question. You can also open the unit and see if there are two or four wires associated with the input power to the transformer. Some can be strapped for either voltage. Finding a replacement transformer would be a real problem.
Another option would be to make an autoformer convertor using a 150 watt control transformer and use only the primary. In autoformer mode, the external transformer needs to be only half the power input sixe so a 150 watt would work. Feed the power to one of the two primaries and put the second in series to add to make 240.volts. They are a little heavy but not that bad. About half the size of a small loaf of bread. These are OFTEN available surplus for cheap.
Jan 18, 2010 | SWR WorkingPro 15 200 Watt 1x15" Bass...
Where to buy fuse
http://www.fender.com/support/amp_schematics/pdfs/Bassman_400_Schematic.pdf Also note there is a thermal protection circuit and a current overload. If the amp turns on and there is no sound start with the speaker to make sure it isn't blown and work backwards through the wiring and connections up to the crossover circuit (all in one cabinet version). On the head separate versions check for a broken output jack problem. The fuses are 10 amp 250 volts for the 100-120 volt models and 5 amps 250 volts for the 230-240 volt models. NOTE: If you are at all unsure about opening your amp up to work on it, take it in to be serviced. It doesn't sound like a fuse problem to me. Necer work on an amp while the power cord is plugged in. Always replace parts with the proper replacement especially fuses. They are there to protect the circuits. If they keep blowing it means there is an internal problem. Remember that capacitors store a lethal charge and it is easy to touch the wrong thing when you are looking inside an amp even if it has been disconnected from power for a while.
Aug 04, 2009 | Music
TC Electronic TC Helicon VoiceLive Touch Portable Vocal Effects Processor Logo
151 people viewed this question
Top TC Electronic Music Experts
Michial Gueffroy
Tom Chichester
Seanzilla
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
