Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Mt dishes dont get clean. my silverware isnt shiny and everything is still wet when its done. also the button dont work sometimes.
  • marcy31093 Mar 14, 2011
    Hi Daniel, thankyou for the suggestion. However I noticed that the model number on my dishwasher does not match the number I see next to my original problem. The model number I find on mine is model LDF6810ST/01. Does this make a difference in our solution or should I try it anyway?
  • marcy31093 Mar 15, 2011
    Ok thanks. Ill try that.
  • 4,323 Answers
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 12, 2011
  • Daniel Scott
    Daniel Scott Mar 14, 2011
    The solution remains same :)
  • Daniel Scott
    Daniel Scott Mar 15, 2011
    Alright :)
The suction cups on my oil rubbed bronze soap dish are no longer tight enough to sick to the wall of my shower. it's been fine for over two years until now. can you buy new suction pieces or do i have...
Sometimes this happens when the suction cups are somewhat dirty.
Wet the suction cups, leave for some time, and wipe with a clean cloth until the suction side is shiny. If it is not shiny at places that suggest those places are not cleaned thoroughly. Wet again and wipe again until you get a shiny surface.
Check the wall where it was attached. If you see any patches wet the area and wipe with a clean cloth.
You can apply just a tad bit of oil (I use coconut oil) to the suction cups.
Try this - and let us know the results.
Thanks for using FixYa!
Sep 05, 2011 | Allied Brass Soap Dish - 432.ORB - Oil...
Residue left on dishes And glassware not properly rinsed and glasswre and silverware not shiny.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 10, 2011 | Whirlpool GU2300XTS 24 in Builtin...
Film on my dishes and silverware
the detergent is not breaking down,it could be hard water try cleaning the soap dispenser,also try vinegar or CLR and run with no dishes.clean out sprayer arms make sure the wholes are not blocked up,and before loading machine rinse off dishes before loading.
Jul 08, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Not cleaning silverware and leaving film on dishes
to much detergant or not enough hot water prime sink before starting dw
Jul 01, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
Dont clean my dishes
Try cleaning out your drain because it could be clogging up and this can cause it not to clean the dishes.
May 19, 2009 | Tappan MDB531RF Dishwasher
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwasher does not clean dishes and leaves spots on everything!!
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Mar 04, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Whirlpool dishwasher
first how old is unit ??? new to you??? a few things to check on your part, for better results run the hot water in your sink b4 you start your d/w. are you using a rinse agent (Rinse Aid) newer machines actually count on this for better drying. is everything soaking wet as if never attempted to dry or are certain items not drying. for example Tupperware, plastics( sippey cups), and some silverware may not ever come dry. newer d/w heat the dish to a certain temp and then rely on the residual heat of the dish to evaporate its own water, and obviously plastics can never be heated to that temp (and certain silverware metal) si the never completely dry. in not saying you dont have a heater issue, but check into these few things first. The heater can be check with a simple continuity test.The heater leads are directly under and behind unit.Sometimes just a visual inspection of heate will deem it bad
Mar 16, 2008 | Dishwashers
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
54 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
