Question about Air Tools & Compressors
Compressor wont build pressure - Air Tools & Compressors
    Master:
  • 403 Answers
Check for leaks, also the regulator is shot. home depot sells replacements
Posted on Mar 12, 2011
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
My craftsmen air compressor wont build pressure. How do i fix it?
If the unit will not build up pressure you need to remove the compressor head from the compressor and inspect both the intake and the exhaust reeds as well as the piston ting on the compressor.
Without the model number of the compressor this is about as far as I can help with.
Sep 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor runs but wont build pressure
You are probably leaking past worn rings and/or through dirty or broken reed valves. You don't mention a make or manufacturer. Contact them for repair parts.
Thanks for your interest in FixYa.com
Feb 23, 2010 | Air Tools & Compressors
Porter cable model 2005 type 3 wont build pressure
The check valve is most likely the problem,or the compressor is bad.The check valve actually holds the air in the tank,without allowing the air to retreat backwards into the compressor.
Oct 17, 2009 | Air Tools & Compressors
Craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Apr 18, 2009 | Air Tools & Compressors
Wont build air pressure
Your problem falls into one of two categories the first is the tank is leaking the second is the compressor is leaking. Try this run the compressor for a minute or two and turn it off if to hear a hiss the tapers off slowly your tank is leaking some were check the drain on the bottom of the tank, the pressure relief valve on the top or side of the tank and all other connections between the compressor and tank.
In the event there is no hiss this means the problem is the compressor you may have a bad reed valve or a bad check valve depending on the type of compressor.
hope this helps
Mar 28, 2009 | Hitachi Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
