Question about Car Audio & Video
I need a manual for a Interfire IB-4700B car amplifier
2 Suggested Answers
music head
SOURCE: amp will not turn on
check all conections, check any fuses,it might be the amplifiers power supplys shot
Posted on Jan 09, 2009
I hooked up my 2 dvc 12in subs to 1100 w interfire ib2900c 2ohm stable amp..however after hooked up subs make very loud bababababa sound when turned on ..what don i do to fix this?
It's in your rca lines or you are missing or don't have good enough ground to your amplifier or CD player. To check this simply unplug your RCA's at the radio it's your radio. If it dosent it's in your rcas
Oct 22, 2015 | Car Audio & Video
2-12 inch kicker comp 4ohms each to conect to a interfire a700.2 amp best wire setup so i dont keep getting a protection led when volume i increased...thanx n advance.
Turn the gain down and try that, usually 25-40 is all you want.
Also make sure the AMP is well ventillated, or it will overheat and cut off...
Id no - go, then wire it without a bridge, two wires from each channel to each speaker.
Jun 17, 2014 | Car Audio & Video
No bass
could be the speaker its hooked up to . try to disconnect the sub and see if the protect light goes out
Feb 06, 2010 | Competition INTERFIRE BIG BOY 2CH...
What kind of noise it will bang or should i go with class d amps
If you run a pair of subs to each amp at a 4ohm bridged load per amp you will get the full power of the amps delivered to your subs-roughly 450 watts per sub as punch amps are all under rated-that sh%&t gonna bump hard - thats an incredible setup from an equipment standpoint- i run 1600watts on a pair of 15z and its freaking obnoxiously LOUD and yours will be moving more air than my 15s so it should be just mind numbing - go for it !!!!!!!!
Jun 04, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
How do i install an interfire IB2400c amp?
Hello blown1914,
That appears to be a good amp and should power your subs with no problem.
You will want to install a line-level converter to your stock speaker outputs and use RCA cables to the amp. Here's a link to SonicElectronix line-level converters. The PAC SNI-35 is OK if your stock radio has a remote turn-on lead. If not, you should probably look at the PAC TRUNK-LOC. It still a 2-channel line output converter but also includes a trigger output to power on your amp.
http://www.sonicelectronix.com/cat_i331_line-out-converters.html
I tried Interfire's web site to see if they have a downloadable manual for your IB2400c amp. I could not find it, so it may be that it is no longer in print or no longer available.
You may want to go to their support page (link attached) and send them an email.
http://www.interfireaudio.com/contact.html
Hope this helps.
Apr 12, 2009 | Car Audio & Video
Amp will not turn on
Jan 08, 2009 | Competition INTERFIRE BIG BOY 2CH...
Subwoofer in my car works only on tuner
I had the same problem. most radios have a power antenna wire and an amp turn on wire it sounds like your amps are being turned on by the power ant wire that loses power when you put a cd in try swapping the blue with blue and white wire this should solve it
Nov 19, 2008 | Sony CDX-GT300 CD Player
Car Audio & Video Logo
207 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
