Question about Car Audio & Video
How do you install the antenna mast? The hidden moter is still working. It is the top thats broken of.
  • 22,219 Answers
You have to remove and replace the whole aerial as its not repairable ,they are not expensive new or a secondhand one from scrapyard
Posted on Mar 12, 2011
Tacoma(1997) power antenna mast with broken cord will not come out after the chrome nut is removed. Any suggestions? Antenna motor still works.
Power Antenna Mast Replacement 97 fjz-80 ' IH8MUD Forum
forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Oct 1, 2010 - I'm looking for a "how to" on replacing the OEM power mast on a 97 LC. ... The only tricky part is removing the funky nut that holds the mast in. .... what to do with the radio mast on my newly acquired 1997 Lexus LX450. ... if I have a broken cable, but the antenna itself comes right out of the top with no cable.
How to rebuild the power antenna - Cadillac Forums
www.cadillacforums.com > ... > Cadillac Tech Tips - How to fix it
May 9, 2009 - 15 posts - ‎12 authors
Remove the liner to access the antenna and disconnect ANY of the two ... If notlocked the motor receives continuously power and will drain ... Broken nylon wire lifting/lowering the antenna mast 4. ... The motor shaft comes out from the plastic casing after you take out ... Do not lubricate the cable or the mast.
Saabnet.comt Broken Antenna FAQ - The Saab Network
www.saabnet.com/tsn/faq/antenna.html
If the cable broke in the antenna, you need to remove the antenna to remove the ... take a 17 mm wrench and remove the nut over the antenna where the mast comes out of the body. ... Hopefully the chrome sleeve will come with the old mast. ... Be careful not to drop them down too far. get the motor assembly on a bench ...Missing: tacoma ‎1997
How To Repair A Broken Car Antenna -EricTheCarGuy ...
? 20:53
https://www.youtube.com/watch?v=zcKwFto9_s0
May 24, 2013 - Uploaded by EricTheCarGuy
This video shows one way you can deal with a broken antenna. ... Find out why ... this video is that I did ...Missing: chrome
Jan 12, 2016 | 1997 Toyota Tacoma
How to remove broken antenna from 1999 ford forte
No Most power antenna work the same. it takes two people to change them. watch and listen as radio is turn on then off do this several times then remove retainer nut turn radio on and assist removal of remaining mast watch where the teeth are located in motor assembly. fully extend new antenna mast lube with machine oil 3 and 1 works great then slowly feed new mast into motor assembly then turn radio off as you guide new mast down install retainer parts work antenna up and down overrun clutch will make the final adjustment.
Nov 09, 2013 | Ford Cars & Trucks
Power antenna keeps running in down position on 1987 Buick Grand National. Is there a fuse I can pull as opposedto disconnecting the battery
Its most likely running because of a broken mast cable.
The ACC fuse powers the antenna. But it also powers the interior lights, door locks, etc..
May just want to go under the dash and find the connector and unplug it.
If you go for an aftermarket replacement mast, not all work.
The cable on that is most likely a smooth cabel with a J hook at the end. Most the aftermarkets have teeth and no hook.
Napa auto parts sells replacements that may work. When the antenna mast did the very same thing on my 89 Camaro I got a replacement from Corvette Central. Pricey for just a top section of the mast but just about all I could find.
Aftermarket antennas are fairly cheap and can work.
Oct 10, 2011 | Cars & Trucks
How do you replace the atenna mast for 2005 sierra.
How do I install a new antenna on my GMC 05 2500 Sierra. I have to replace the base because it broke off. I've taken the dash off. But cannot seem to fish wire through the firewall.
Nov 26, 2010 | 2005 GMC Sierra
Antenna MOTER KEEPS RUNNING DRAINS BATTERY CANT FIND HOW IO DISCONNECT IT. WHEN I TAKE OUT FUSE IT DISCONNECTS HORN EXT
If you can reach the motor simply disconnect the wires. Cap the wire ends to prevent a short.
Jun 13, 2010 | 1992 Buick Century
Need to know how to remove a regular antenna from a 1996 Toyota Tacoma. It is not a power antenna.
Toyota Pick-ups/Land Cruiser/4Runner 1989-1996
Antenna - REMOVAL & INSTALLATION
If your antenna mast is the type where you can unscrew the mast from the fender, simply do so with a pair of pliers. Most damaged antennas are simply the result of a truck wash or similar mishap, in which the mast is bent.
Manual Antenna
  1. Disconnect the antenna cable at the radio by pulling it straight out of the set. Depending on access, this may require loosening the radio and pulling it out of the dash.
  2. Working under the instrument panel, disengage the cable from its retainers.
On some models, it may be necessary to remove the instrument panel pad to get at the cable.
  1. Outside, unsnap the cap from the antenna base.
  2. Remove the screw(s) and lift off the antenna, pulling the cable with it, carefully.
To install:
  1. When reinstalling, make certain the antenna mount area is clean and free of rust and dirt. The antenna must make a proper ground contact through its base to work properly.
  2. Install the screws and route the cable into the cab. Make certain the cable is retained in the clips, etc.
  3. Connect the cable to the radio; reinstall the radio if it was removed.
Power Antenna Mast
The power antenna system contains a relay. If the power antenna is inoperative, the relay is the first place to look. The actual motor rarely fails.
The power antenna mast is replaceable on the Pick-Up and 4Runners. If the mast is damaged or broken, proceed as follows:
  1. Perform this repair with the battery cables connected. Turn the ignition switch to the LOCK position.
  2. Remove the antenna nut.
  3. If equipped with a CD player, press the AM and FM buttons on the receiver and simultaneously turn the ignition switch to ACC .
  4. For non-CD player units, press the AM button and simultaneously turn the ignition switch to ACC .
  5. The antenna motor will run, unwinding the mast from the spool. have an assistant guide the mast so it doesn't fall and damage the bodywork. When fully extended, the mast will be released. Remove it, and leave the ignition in the ACC position.
To install:
  1. Insert the new cable so that the teeth face the rear of the vehicle. Feed the cable into the motor until the cable reaches the bottom, about 12 in. (30cm).
  2. Have an assistant ready and prepared to guide the cable. Turn the ignition switch to LOCK . The motor will run, winding the cable onto the spool and drawing the antenna down into the mount.
  3. If the cable does not wind, twist the cable at the top of the housing; the part at the bottom may have turned while being pushed down the hole.
  4. Once wound onto the spool, install the antenna nut even if the antenna is not fully retracted. Test the antenna elevation and retraction; the mast will eventually retract fully.
Hope helped with this (remember rated this post).
Feb 26, 2010 | 1996 Toyota Tacoma
How to replace thunderbird antenna
please rate service.
Automatic Electric Antenna
Removal
  1. Lower electric antenna (18850) .
  1. Remove rear retaining screws of RH front wheel splash shield for access to antenna lower retaining bolt.
  1. Remove lower retaining bolt.
  1. Remove radio antenna nut (18865) from top of motor tube and remove electric antenna through fender/splash shield access.
  1. Disconnect signal cable and motor wire connector(s).
Installation
  1. To install, reverse Removal procedure.
  1. Tighten top radio antenna nut to 6-8 Nm (54-70 lb-in).
  1. Tighten lower electric antenna retaining bolt to 5.8-7.8 Nm (51-69 lb-in).
  1. Check operation of electric antenna and radio chassis .
mast
Mast, Power NOTE: A power antenna mast which is bent or broken can be replaced without replacing the motor and tube assembly.
Removal
  1. Remove radio antenna nut (18865) and radio antenna stanchion (18919) .
  1. Loosen retaining nut inside tube using 14 mm (9/16 inch) socket, and slide nut part-way up mast.
  1. Raise antenna to run plastic drive wire at bottom of mast out of motor. Note direction of teeth on plastic drive wire.
  1. Saw off damaged portion of antenna mast. Remove burrs from mast and slide nut and contact tube off stationary tube.
Installation
  1. With the teeth on the plastic drive wire facing toward motor on antenna, push end of plastic drive wire of replacement mast assembly down into tube. Push it around curve at bottom of tube until end enters drive mechanism.
  1. Run motor down while pushing on plastic drive wire until about 305 mm (12 inch) of wire has been drawn into the tube. Stop motor and insert bottom of antenna mast into tube. Lower mast.
  1. Slide contact tube and radio antenna nut down antenna mast. Tighten nut to 0.45 Nm (4 lb-in).
  2. Raise and lower antenna several times to ensure proper operation.
Jul 09, 2009 | 1995 Ford Thunderbird
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
Replace antenna on 2003 mr2 spyder
my antenna just stopped working in my MR2 2003 Spider. The motor still runs but the antenna will not go up and down. It made a weird noise and I had to pull the top of the antenna up to stop the motor from sounding loud.
Should I replace this or can you disconnect it and push the antenna up and down?
Thanks
Aug 28, 2008 | 2003 Toyota MR2 Spyder
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
