Question about Gateway 816GM PC Desktop
I have broken headphones and michrophone jacks on the front of the computer. Where can I find the component part # and where can I get a replacement?
    Scholar:
  • 155 Answers
Please the following link and click on show part number under Audio Jack, you will see the following image:
If you follow this link you will have few options to order your part.
Please let me know if you need additional information.
Regards
Posted on Mar 12, 2011
    President:
  • 2,653 Answers
Can you confirm the model of your computer? I should be able to help you figure out to fix on the cheap ;)
Headphone jack is broken INSIDE the port and is overriding the speakers. Can I override this override?
Or instead of having to open up your computer and messing with the mobo. Just use the control panel in to disable the headphone jack.
May 09, 2014 | Dell OPTIPLEX 745 PC Desktop
Audio input jack for headphone component broke off need to find new input and how to replace
No way to do that unless you can figure out a way to remove the part. The contacts inside that plug determine where the sound goes. No way to turn it off unless you remove the broken part. If you feel confident enough, remove the back of the TV and remove the broken piece from the jack.
Mar 02, 2014 | LG 32LD350 32 in. LCD TV
Sound from headphones on computer terrible
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards You will need to open up your computer to check the back of the input headphones plug look for dusty and bad soldering or loose connections. b> Computer Headphone Jack Has Fuzzy Noise b> When building a computer system, making headphone and microphone jacks are one area where computer manufacturers use the lowest-cost parts. When it comes to computer audio, no perceivable difference in sound quality exists between that of ordinary parts and higher quality ones. Very low-quality parts, or parts that are installed with sub-par wiring, however, can lead to fuzzy sounds and static on headphones.
Symptoms and Component Isolation Start the diagnosis by using different headphones in the jack. If the fuzzy noise or static problem persists over multiple headphones, even if it doesn't happen with all of them, it's probably within the jack on the computer. This is also probably the case if the static increases when you do other things on the computer, like dragging windows around on screen with your mouse, then stops when you stop dragging windows. Causes b> The leading cause of headphone jack static is electromagnetic interference from other components in the computer's case. When electrical devices draw current, they also generate a magnetic field. Overlapping magnetic fields cause static. To combat this effect, the manufacturer provides for the components on motherboards to be grounded - the wiring from the microphone jack will have an extra lead that goes directly to a grounding agent. When your computer headphone jack has a fuzzy sound, or static, the ultimate cause is usually bad grounding on the wiring that the jack plugs into. Rewiring The Jack b> If you're comfortable with a soldering iron, and know enough about electronics and wiring, you can remove the wire to your microphone jack and put in one with heavier shielding, or a better ground. If you're not comfortable with this, a computer repair shop may be willing to tackle this for you; the actual cost in labor is about an hour to an hour and a half of labor time. It may be less if the shop technician is familiar with this sort of repair, as opposed to only knowing how to swap cards on the motherboard. Using Different Ports for Audio Cheaper alternatives exist than rewiring the headphone jack on your motherboard. One of them is to put in a dedicated sound card - which will cost $15 or so, and you may have a compatible one from an old computer that can be scavenged. This will require researching the make and manufacturer of the card to download compatible drivers off the internet, and then installing them on your computer. If you have an unused USB port, the easiest solution is a pair of USB headphones. This has the advantage of working with future hardware as well.
How to reduce static in my audio http://www.miracletutorials.com/how-to-reduce-static-in-audio/
Feb 27, 2013 | Computers & Internet
Dell inspiron 1525 not getting any sound out of headphone jack...I have 2 headphone jacks on the front of my computer. The right one has always worked when I plug headphones or sound cord in. Today, I...
The jack might need replacement since it may be broken on the inside. Also check with your headphones on anther known working device to make sure that the issue is not with the headset.
Sep 03, 2017 | Dell Inspiron 1525 Laptop Computer PC...
Input fitting on headphone has broken,can this be fixed?jack wont stay plugged in
Hello. Yes it can be fixed. Take your headphone to any radio shack store and show it to one of the technicians there. They will show you the component you need to make the repair. Many times, a dab of one minute clear epoxy will mend too. Regards, Joe
Jan 09, 2010 | RCA WHP160T Consumer Headphones
Headphones
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
May 20, 2009 | HP w1907 LCD Monitor
AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
Headphones plug not working right. can hear only from one, even if connectec to speakers
That is a common problem with Mp3 players - unfortunately, no one that I know of yet has been successful in repairing this issue, b/c the manufacturers do not sell the component parts. I'm afraid this Mp3 player will have to be replaced, even though only the headphone jack and associated circuit are bad.
Jun 24, 2008 | Audio Players & Recorders
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Gateway 816GM PC Desktop Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
