How do i open the remote (R11 CG/E) to replace the batteries?
  • 1,420 Answers
Sometines they hide the batteries under the cover that slides (if your does), Pull the slide up farther to expose batteries.
Posted on Mar 12, 2011
How do I know if the battery is charging or if I need a new one?
Your need a volt meter
1.read the voltage of the battery
2.charge battery 1/2 hour
3..read the voltage of the battery if it has increased the battery is charging
Jun 24, 2016 | GE Cg 9808se Hq Vhs Movie Video System...
General electric hq moviemaker cg 9908 how do i no if batterie is charging
On some chargers the light goes off when charged, read the manual it should tell you. On other chargers you guess or buy a smart charger.
May 25, 2014 | GE Cg 9808se Hq Vhs Movie Video System...
One will not charge How to change batteries
There's a small half-round clip at the bottom, open that, then you are able to lift the battery cover and swap batteries.
Apr 10, 2014 | Cobra FA-CG Micro Talk Walkie Talkies
The door will not lock
There is a small actuator that locks the door before the spin cycle located in the door latch assembly. This actuator is called a wax motor, Maytag part # 12002535 is the redesigned part. It works by heating a ball of wax up which causes the actuator pin to push out and lock the door. It takes around 45 seconds to extend so it is rather slow compared to a typical electromechanical solenoid. The older wax motors have a brown actuator pin while the newer version has a black actuator pin.
The wax motor failure is caused by moisture penetrating the wax motor (older design) over time, which causes the electrical resistance to drop to such a value that the small Q6 triac located on the upper control board overheats and shorts out internally. The triac is essentially an electronic switch that is controlled by a low control voltage, which is provided ultimately by the processor U1. The R11 overheats because the failed Q6 is allowing 120 volts on the triac's center control pin. When this happens, R11 burns and opens up electrically. Sometimes Q6 still looks normal and other times the plastic case ruptures after the failure. However, a burnt R11 is the telltale sign that you have had this failure and the Neptune washer should be left off to prevent further damage to your upper control board.
To inspect your control board you need to do the following:
1. Unplug your Neptune's power cord.
2. Remove three Philips screws along top of washer console.
3. Pull top of control console towards you while pushing bottom of console away from you.
4. Control board is located behind timer assembly on back panel.
5. Inspect the R11 resistor located near the left control board mounting screw.
If your R11 is burnt, you have two options. The first is to repair the control board and the second option is to replace the control board. To repair your control board you will need a 25-watt pencil type soldering iron, solder, diagonal cutters, needle nose pliers, replacement Q6 and R11 components. Whether you repair or replace control board I would not power up machine until the new wax motor is installed or you risk damaging your repaired or new control board again.
If you have not experienced the No-Spin problem consider yourself lucky because you are now aware of the issue and can replace the wax motor before you have a failure. You need to inspect your door lock wax motor and make sure you dont have the older style with the brown actuator pin. Note: If you identify that you have the older brown pin wax motor you need to replace it a.s.a.p. so you don't experience the R11/Q6 failure. I would not use machine until the original wax motor is replaced
Dec 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer does not drain. Checked r11 resistor
Unfortunately, you cant replace the resistor, you need to replace the board. The cause of the R11 resistor blowing, is the wax motor for the door lock assembly. When the wax motor shorts out, the surge blows the R11 resistor on the board, requiring you to replace the wax motor and an expensive board. Major enginering error by maytag. The board costs around $240 and the wax motor is around $15
Oct 16, 2009 | Maytag Neptune Washer
MY FORD TAURUS 1996 IS RUNING AND SUDENLY STOP AND IS DEAD, WHY.
tv1709~us~en~file=adobe.gif~gen~ref.gif Printable View (11 KB) Article No.
97-17-9
  • STALL - ON DECELERATION AND/OR INTERMITTENT STALL IN WARM WEATHER - VEHICLES BUILT THROUGH 8/18/96 AND SHO BUILT THROUGH 8/6/96
Publication Date: AUGUST 18, 1997
FORD: 1996 TAURUS SHO, TAURUS LINCOLN-MERCURY: 1996 SABLE This TSB article is being republished in its entirety to correct a service part number. CALIBRATION: 6-10A-R07, 6-10A-R10, 6-10A-R11, 6-10A-R12, 6-10S-R07, 6-10S-R10, 6-10S-R11, 6-10S-R12, 6-10B-R06, 6-10B-R10, 6-10B-R11, 6-10B-R12, 6-10T-R06, 6-10T-R10, 6-10T-R11, 6-10T-R12, 6-14A-R07, 6-14A-R08, 6-14A-R10, 6-14A-R11, 6-14S-R07, 6-14S-R08, 6-14S-R10, 6-14S-R11, 6LDA-JAD tv1709~us~en~file=caution.gif~gen~ref.gif WARNING: THIS MODIFICATION IS AUTHORIZED ONLY FOR THE LISTED ENGINE. PERFORMING THIS MODIFICATION ON OTHER ENGINE CALIBRATIONS IS UNAUTHORIZED AND COULD CREATE LIABILITY UNDER APPLICABLE FEDERAL OR LOCAL LAWS. ISSUE: Some vehicles may stall on deceleration and/or have an intermittent stall in warm weather. This may be caused by the vapor control valve not supplying a steady flow of fuel from the tank to the intake manifold.
ACTION: Replace the fuel tank, vapor control valve, fuel fill tube cap and clamp. Install heat shield over fuel tank and reprogram the Powertrain Control Module (PCM). This should reduce the possibility of stalling. Refer to the following text for details.
Perform all diagnostics for stalling by following the procedures outlined in the 1996 Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual and 1996 Taurus/Sable Service Manual, Pages 03-13-5 through 03-13-8. Check to be sure Grounds 401 (sedans) and 400 (wagons) are secure. Check for a kink in the canister vent hose and repair as required. If no other concerns are found, reprogram the PCM using the latest level CD-ROM update disc and refer to the following PCM Application Chart for correct PCM usage. Replace the fuel tank, vapor control valve, and vapor management valve by following the procedure outlined in the Instruction Sheet included in the Fuel System Service Kit.
PCM APPLICATION Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 6-10A-R07,R10, R11, R12 F6DF-BF 6-10A-R12 F6PF-CVB 6-10S-R07,R10, R11, R12 F6DF-DF 6-10S-R12 F6PF-CYB 6-10B-R06,R10, R11, R12 F6DF-JD 6-10B-R12 F6PF-CXA 6-10T-R06,R10, R11, R12 F6DF-KD 6-10T-R12 F6PF-CZA 6-14A-R07,R08, R10, R11 F6DF-EG 6-14A-R11 F6PF-CGA 6-14S-R07,R08, R10, R11 F6DF-FG 6-14A-R11 F6PF-CFB 6LDA-JAD F6DF-RD 6LDA-JAD F6PF-CDA
Sep 01, 2009 | 1999 Ford Taurus
Won't spin
hi..
What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11)
just pull the board u can discover burn thru on r11 (you can see the blackened resistor). orders and new board & wax motor on ebay. open the washer & replace the board & wax motor..
thank u
rate me!!!
Apr 13, 2009 | Zanussi Washing Machines
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Neptune washer
The R11 burns because the wax motor jams. If the R11 is burnt, it is time for a new circuit board. These are availible on line from the manufacture or at local appliance stores ( I use first source parts). To forwarn you, circuit boards can be pricy. Once you have the circuit board, it is just a case of unplugging on connection at a time and plugging it back in to the new board. To replace your wax motor, you firs must take the 4 screws out of the door frame to the right and left as you open the door. Once you do that the front panel will come off. Then you must remove the 4 screws from the dispenser door. Finnally, you must remove the the 2 5/16 screws holding down the lid. It will then lift up and the wax motor will be right at the front.
Jun 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
