Question about AT&T E5634B Phone System w/ Caller ID
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the hand set using the ID number on the bottom of the base. The phone accepts it with no problem. the screen on the handset goes blank and about 5 minutes later the hand set request the base ID again. This happens no mater which hand set I use, and I have tried each hand set and number of times. I have the manual, and have reset the base charger. Please help...what is the problem????
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Posted on Apr 22, 2017
4 Suggested Answers
SOURCE: I can not get the handset to charge. Tried a new battery and all solutios in manual
This happens pretty regularly at my house. The solution is pretty simple. I take the batter out and put it back in and put it back into the cradle.
I have four kids at home and the phones are banged around quite a bit. I think the battery just loses a solid connection to the terminal points.
Now, can someone help me find a way to get my teenagers to implement this fix when they hear the battery beeping because of low battery?
Cheers,
Mike
Posted on Feb 08, 2008
jyackle5
  • 8197 Answers
SOURCE: How to de-register handset from
First deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
Posted on Apr 06, 2011
SOURCE: I need to de-register an
When the handset is searching for the base, click the new button, then enter the 15 digit base ID number into the handset.
Posted on Jun 04, 2011
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
1. press [menu]
4. scroll from "Test Base" to "Test Handset", press [select]
press [select]
replace the cover
( III.) To register the cs6114 handset to the base:
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
In that case, you can clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
Is it possible to change the Panasonic KX-TG6541 hand set numbers ? speaker stopped working so I want to change handset #1 to Handset #4 & Handset #4 to Handset #1
yes de-register most of the phones from the base station and then
re gister them in the correct order to get the desired numbers. You have the instruction manual from my earlier post so just de register most of the phones being 2 to 4 and re resister them in the desired order .
Dec 20, 2014 | Panasonic Lands Phones
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to...
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Jan 04, 2011 | Vtech SL80108 1.9 GHz 1-Line Cordless...
Handheld won't communicate with the base
i have the same problem and it has happened infrequently several times. you probably have to deregister the handset and re-register it and rest the base and handheld to communicate since my model is different from yours there may be differences in how to go about it but for my model the suggestion is as follows:
go to www.uniden.com for customer support here is a direct link to some frequentlt asked questions http://www.mycusthelp.com/uniden/supportfaq.asp?sSessionID=&lstFilter_a=&lstFilter_b=&lstFilter_c=&txtCriteria=hanset+won%27t+connect+to+base&optcond=2&iStartCount=1
DCT Series Multi Handset Phone - reset to have base and handsets communicate
Question:
I have a DCT Series Multi Handset phone and one or more of the handsets is not working, what should I do?
Answer:
Try resetting the phone system by using the following steps:
1) Enter the "System Reset" menu, then "Deregister HS" submenu.
2) Press volume/up or down arrow keys to select the handset ID to be de-registered from the list, then press the OK soft key.
3) Press the OK soft key. You will hear a confirmation tone. When de-registration is complete, "Deregistration Complete" appears.
4) After de-registering the handset, move to "Replacing the Base Setting" below. When you go through the deregister procedure if you get "out of range", That is okay. Go ahead and go to the next step.
1) Enter the "System Reset" menu, then "Replacing Base" submenu. "Do you want to replace Base?" appears.
2) Press the OK soft key. You will hear a conformation tone. The base information will be deleted. When replacing the base is complete, "Please Register" appears, register the handset to the new base.
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
To resolve out of range follow the below steps.
Press and hold the end key.
Press and hold the # key.
Release the keys and select replacing base and press select.
You will see Replace base?
Select Yes and press select.
Now place the handset on the base and it should register to the base and allow for calls to be made.
Jan 23, 2008 | Uniden CXAI5198 Corded Phone
Cheers,
Mike
Jan 21, 2008 | AT&T E5634B Phone System w/ Caller ID
AT&T phone model E5634B
SOLUTION to AT&T Cordless Telephone/Answering System 4 phone set Model E5634B - Cannot answer incoming calls nor does caller ID work on phones.
Unplug the base for a few minutes, plug base back in, remove and reinsert the battery on each phone that does not work, then place each handset in the base for few minutes. Worked for me...all 4 phones can be answered and caller ID works!!! Hope this works for you... :o)
Jan 12, 2008 | AT&T E5634B Phone System w/ Caller ID
AT&T E5634B Phone System w/ Caller ID Logo
54 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
