Need to register router name and password - Computers & Internet
  • 1,591 Answers
These are of your own choosing. Make sure the password is something you can remember.
I always suggest writing down the information you enter here on a slip of paper, and keeping that slip underneath the router itself.
Posted on Mar 12, 2011
I want change my liksys roter password E900.can any help me please My no is 0506327008
Please click EDIT and remove your phone number. No one here phones anyone except the 'crazies' who are tuning in!
All the information is online. videos in the main link at the bottom.
  • Linksys E900 Default Password - About.com Tech pcsupport.about.com > ... > Linksys Default Passwords 2016-04-07 · Find the Linksys E900 default password, ... your Linksys E900 (N300) router. ... on the bottom of the router. Be sure to change the default router ...
  • Linksys: Changing the Wireless Network Password for Your ... kb.linksys.com/Linksys/GetArticle.aspx?docid=67993c06bf0c4b1f... We would like to show you a description here but the site won't allow us.
  • Linksys Official Support - E900 Frequently Asked Questions www.linksys.com > Home > Support E900 Frequently Asked Questions. ... Username and Password of the Linksys Wi-Fi Router, E900? ... so you do NOT have to call your ISP to change the registered MAC ...
  • Linksys Official Support - Linksys E900 N300 Wireless Router www.linksys.com > Home > Support Linksys E900 N300 Wireless Router ... Login & Password. Changing the router's wireless network name and password using ... Changing the Linksys router's ...
  • Linksys Official Support - Changing the router's wireless ... www.linksys.com > Home > Support ... E1550, E1700, E2000, E2100L, E2500, E3000, E3200, E4200 v1, E800, E8350, E900, ... Linksys router name or password. ... change your wireless network's password ...
  • Linksys E-Series Routers User Guide downloads.linksys.com/.../E_Series_UG_E900Rev_3425-01486_Web.pdf · PDF file Linksys E900 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ... How to change your router's name and password . . . . . . .
  • Solved: Linksys E900 router - Page 2 - Linksys Community
  • Go to Bing homepage
    Jul 10, 2016 | Cell Phones
    Hi i have 1841 router what is the default user name password for this i tryed with user name passowrd as cisco but is saying that no user cisco pls help me
    • Follow these steps in order to recover your password:
      1. Attach a terminal or PC with terminal emulation to the console port of the router.
        Use these terminal settings:
        • 9600 baud rate
        • No parity
        • 8 data bits
        • 1 stop bit
        • No flow control
      2. If you can access the router, type show version at the prompt, and record the configuration register setting.
        Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
      3. Use the power switch in order to turn off the router, and then turn the router back on.
        Important Notes:
        • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
        • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
      4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
        If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
      5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
        This step bypasses the startup configuration where the passwords are stored.
      6. Type reset at the rommon 2> prompt.
        The router reboots, but ignores the saved configuration.
      7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
      8. Type enable at the Router> prompt.
        You are in enable mode and should see the Router# prompt.
      9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
        Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
      10. Type show running-config.
        The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
      11. Type configure terminal.
        The hostname(config)# prompt appears.
      12. Type enable secret password> in order to change the enable secret password. For example:
        hostname(config)#enable secret cisco
      13. Issue the no shutdown command on every interface that you use.
        If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
        Router#show ip interface brief
      14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
        hostname(config)#config-register 0x2102
      15. Press Ctrl-z or end in order to leave the configuration mode.
        The hostname# prompt appears.
      16. Type write memory or copy running-config startup-config in order to commit the changes.
    Jul 02, 2010 | Cisco (1841) Router (cisco1841)
    Hot to make my gateway 2700hg-d modem/router
    you just need to things for ATT your user name and password that you registered to them. Then you need to get inside the 2wire by using the IE or Mozilla. On the address bar, type in 192.168.1.254. Inside you will see there setup then just follow the prompt but if you got lost on the process just call att dsl
    Mar 07, 2010 | 2wire 2700HG-B Router (2700HGB)
    I haven't got the password to register my netgear
    default password is the same believe it or not
    admin
    admin
    easy so to rest these things there should be an indented pushbutton on the back side .. use a ben to trip it.
    Jul 27, 2009 | NetGear DGN2000-100NAS Router
    Remote manage a DSL 504T router
    If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
    1. Register a name in dyndns.com
    2. update this on your dsl router
    Wait for some time,
    3. access the registered name from anywhere using a browser
    Jun 09, 2009 | D-Link DSL-504T/EU Router
    Don't know username and passw
    Please try username: admin
    password: 1234 or password
    For sure there is a default password of your router at the back or bottom of your router.
    or see the usermanual configuration.
    melnavz
    Oct 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
    NETGEAR LOG IN
    First try to register your product and then try to login with that user name nad password
    Jul 31, 2008 | NetGear RangeMax WPN824 Wireless Router...
    Forgotton name and password
    have you tried admin and password? The defaults if you haven't changed them.
    Or if you did.
    Reset for most routers with a reset button on the rear panel
    Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
    1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
    2. Release the button.
    3. Wait for the router to reboot.
    4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
    5. Unplug the router's power.
    6. Press and hold the reset button. While the button is held down, reconnect router's power.
    7. Continue to hold the reset button for 20 seconds after reconnecting the power.
    8. Wait for the router to reboot.
    9. Log in with the default password.
    Jul 14, 2008 | NetGear WGR614 Router
    I have a model WRT54G model that belonged to my niece and has been registered.She tried to download and set this up on my computer but could not get it to work.I am now onfast ascess dsl and I cannot get...
    To reset your router, use the following steps (you will have to re-setup your router:
    Press the reset button for 30 seconds.
    The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
    Open up your Web browser and enter 192.168.1.1 in the address bar.
    For the login, leave a blank ID and enter admin as the password.
    The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless Router to secure your router
    Apr 05, 2008 | Computers & Internet
    Computers & Internet Logo
    11 people viewed this question
    David Payne
    David Payne
