Question about Eidos Interactive Imperial Glory for Windows
IMPERIAL GLORY - MOUSE STUCK ON CONTENTS PAGE - CANNOT SELECT ANYTHING ! RUNNING WINDOWS 7 - HAVE CHANGED COMPATIBILITY MODE AND DOWNLOAD THE 1.1 PATCH.
My mouse scroller is not working
The above symptom is associated with, but not limited to, the following systems:
  • ThinkCentre M70e, M70z, M71e, M76, M77, M80, M81, M90, M90p, M90z, M91, M91p, Edge 71z, Edge 91z
Applies to:
  • Microsoft Windows 7 in XP Mode
The system is configured with the following:
Windows XP Mode in Windows Virtual PC on a computer that is running Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Lenovo USB mouse driver for Windows 7 (Lenovo Mouse Suite)
Additional Information:
As of writing this tip, Lenovo Mouse Suite Version 6.48 can be downloaded.
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS014888
Lenovo USB mouse driver for Windows 7 (32-bit and 64-bit), Vista (32-bit and 64-bit), and XP.Uninstall Lenovo Mouse Suite.
  1. Click Start, then click Control Panel, View By: Category.
  2. Under Programs, click Uninstall a program.
  3. Right-click Lenovo Mouse Suite, then click Uninstall/Change. You may see a dialog stating, "Windows needs your permission to continue." If you see this dialog, click Continue.
  4. Follow the instruction on the screen to complete the uninstall process.
Other steps.
If you still need some Lenovo Mouse Suite function under Windows 7, the following steps may effective.
  1. Mouse Properties
  2. Select "Lenovo" Tab > Advanced Properties.
  3. Select "Wheel" Tab
  4. Change Wheel setting to "Use Microsoft Office 97 Scrolling Emulation Only" from "Enable Universal Scrolling."
Feb 26, 2013 | Lenovo Computers & Internet
How to download from Hitachi DZ-MV350A video camera to my computer that uses windows 7. I tried the enclosed dvd but it does not work on windows 7.
Your best bet is to use the drivers from the CD.
To do this on windows 7, you'll need to use compatibility mode.
Browse to the contents of the cd in windows explorer. Right click on the driver installer file, and select "properties".
Select the "compatibility" tab from the properties window, and select "windows xp sp3" from the drop down menu. Also tick the "run as administrator" on the bottom.
I did this with my own hitachi DZ_MV350A and it worked just fine.
Dec 02, 2012 | Hitachi DZ-MV350A DVD Camcorder
Sigmaplot 9 will not run with windows 7
1. Click the RIGHT mouse button on the icon for "SIGMAPLOT 9"
2. On the menu that appears click "PROPERTIES" with the left mouse button. This will give you a properties window.
3. Click on the "COMPATIBILITY" tab at the top right of the properties window with the left mouse button.
4. Tick the box "RUN THIS PROGRAM IN COMPATIBILITY MODE FOR:"
5. Click the drop down arrow and select the version of windows it ran in before or try "Windows XP Service Pack 3" and click APPLY.
If that doesn't solve the problem repeat steps 1 to 4 and this time select windows 2000. This should solve the problem.
Apr 20, 2012 | Systat SigmaPlot 9.0 (000053608314) for PC
Network drivers
Please use the following web link to download the drivers.
http://www.mercury-pc.com/downloads_list.php?productid=644
Aug 21, 2011 | Mercury P4VM800M7 Motherboard
I can not load my creatacard gold software into my pc with windows 7. It worked fine with XP and Vista. How can I fix this
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
*Please rate this solution with Thumbs Up
Nov 26, 2010 | Broderbund American Greetings Creatacard...
I changed my os to window 7 and my webcam is not working at all.
Unfortunately Logitech do not support Windows 7 for older products - You can try downloading software and running the cam in Compatibility Mode
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to run the support software - Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click Start, click Run, type dxdiag in the Open box, and then click OK.
Procedure to re-install Logitech software
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options during the installation - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties'
Select the 'Compatibility' tab
Select 'Compatibility Mode'
Use the dropbox to show the OS you have successfully used before
Click OK
Restart your computer
Aug 28, 2010 | Logitech QuickCam Home Webcam
Compatability issue
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Jul 09, 2010 | Broderbund American Greetings Creatacard...
I just install window 7, and now my motiion eye on my vaio vgn-cr120e doesn't work, what can i do?
Click on the Sony support page and download the VISTA driver for this device and follow the compatibility guide below.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR510E&upd_id=3586&os_id=28
I
Here are the steps to run the web cam driver in Vista compatibility mode:-
1. Right click on the web cam driver.
2. Click Properties
3. Click on Compatibility tab,
4. Put a check mark on Run this program in compatibility mode
5. Select the operating system as windows Vista
under Privilege Level, check mark "Run this program as an administrator"
6. Click on Apply
7. Click OK.
If you need to see an illustrated view of this procedure, click on the link below.
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Jun 26, 2010 | Sony VAIO VGN-CR120E Notebook
Belkin bluetooth mouse unable to work with windows 7
try installing the driver for mouse in a compatibility mode....
rightclick on driver file >properties >select compatibility tab > check mark in the checkbox "run this program compatible for" and select windows xp....
guess it ll work fine....
good day....
Mar 03, 2010 | Belkin Bluetooth f8t041-b Mouse
I have IDD Desktop Sheet music 2003 XP and I now have a Windows 7 computer. What do I do to use this program again.
Hi there and welcome at Fixya, the support team (lfete)
You can first try to install it on the computer and select the compatibility mode for Windows xp, I mean you can start right away with the setup file and choose the compatibility mode for xp, you do it in this way:
For choosing the compatibility mode for earlyere versions of windows you do it in this way :
Highlight the file and right click on the mouse and select Properties. Find the " Compatibility " tab and choose the Windows version you want to have. Thats it :O)
ANOTHER WAY TO DO IT :
You can download and install "Win 7 XP modus" and try to run your xp compatible programs, many programs should run on this add-in software from Microsoft (windows).
Windows 7 Xp Modus link :
Hope it helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Feb 11, 2010 | Midisoft Desktop Sheet Music 2.0 Full...
Eidos Interactive Imperial Glory for Windows Logo
185 people viewed this question
Top Eidos Interactive Video Game Consoles & Games Experts
Hanzu
Michael Vincent Cruz
James Wishart
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
