Question about Krups Super Automatic XP 9000 Espresso Machine
Need replacement high pressure hose.approx 7cm long for xp9000, internal diameter 5mm, ext dia 8mm. any ideas?
  • 5 Answers
Jura machine uses the same hose. Have just purchases one from Services Unlimited Inc. Jura Reinforced Silicon Hose 4.2x8.0x80mm item no. 0010681. email sales@partsguru.com
Regards,
Eric
Posted on May 30, 2015
Hi. have same prob with mine try groupe seb aust.ph0297487944
Posted on Apr 29, 2011
Need to know what the evap hose looks like
A/C systems have two hoses, a smaller diameter one for high pressure and a larger diameter one for low pressure. High pressure freon is compressed in the compressor and and pumped under pressure in the smaller hose to the evaporator where the freon is expanded/evaporated and becomes cooler via the expansion process. Here the freon absorbs heat. The larger hose then carries the expanded/evaporated freon to the radiator where it is cooled, then on to the compressor.
Oct 17, 2016 | Cars & Trucks
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Determine what size bleed nipple i need
you will need a 22mmx 5mm bleed screw and the spanner size will be determined by the maker.. Best get the replacement from a wrecker and get exactly the same as you have.
Jul 21, 2013 | Cars & Trucks
Where is the low pressure a/c port on a 2002 jeep laredo for recharging a/c
This job requires special tools and special training. If you lack either, you risk SERIOUS personal injury. Injury comes VERY EASILY!
You need to address oil levels, proper and legal refrigerant recovery, system evacuation, and recharge.
You were planning to also replace the receiver/dryer, correct? It also needs the oil in it measured and incorporated into the amount of oil (in %) that would need to be added. FAILURE to address these and other issues will guarantee premature system failure and likely compressor damage.
Take this job to a qualified shop.
Sorry
Oct 15, 2010 | 2002 Jeep Grand Cherokee
Need way of fixing pipe into fitting inside dishwasher
Fix a worm clip for this diameter and tighten. Also see whether you used the correct size of the hose. Otherwise tie with a strong copper wire of suitable dia.
May 02, 2010 | Dishwashers
Where is the thermostat located between top
On 1998, 4.6 32 valve engines, the thermostat is located in the radiator to block hose. if you look directly under the power steering reservoir you should see it.
The thermostat has 3 hoses running from it. 2 are approx. 1.5" in dia. and one is approx .750" in dia. The .750" hose leads up to the coolant reservoir. and yes it is under the power steering reservoir. Access to the thermostat is from the bottom side. You will need an 8mm socket to remove the two bolts. Removal of the bottom radiator hose is mandatory.
Hope helps with this (remmeber rated this help).
Mar 08, 2010 | 1998 Lincoln Mark VIII
Where is the low side a/c port on 2001 lincoln ls?
There should be two lines/hoses that come from the compressor. If you can locate these lines, the low pressure side is the larger diameter line or hose. The high pressure side is the smaller diameter line/hose. The re-charge goes into the larger, low pressure side.
Jul 14, 2009 | 2004 Lincoln LS
Where is the thermostat located on a 1997 lincoln mark 8?
The thermostat has 3 hoses running from it. 2 are approx. 1.5" in dia and 1 is approx .750" in dia. The .750" hose leads up to the coolant reservoir. and yes it is under the power steering reservoir
Mar 28, 2009 | 1997 Lincoln Mark VIII
Replacement screws for connecting the power wires
The smaller screws should have been 5mm dia with a 0.8mm thread pitch. The larger ones are probably 8mm dia. with a 1.25mm thread pitch.
Is 5/16 too large or too small? If 5/16 is too large, the screw is probably 7mm.
Do you have one of the original B+/ground screws? If so, it should be easy to measure it and get the correct size.
Apr 25, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Krups Super Automatic XP 9000 Espresso Machine Logo
283 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
