Question about Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10
I replaced my Sony KDF-46E200 lamp and it worked for a couple hours. Seller sent me another and the same thing happen again. The filament inside would explode. Each time I put the old lamp back in and it worked fine. I asked another seller about this and they said maybe I have a ballast problem. If there was a problem somewhere else then why does the old lamp work? Confused!
  • wsmith267 Mar 12, 2011
    I purchased lamp on E-bay, seller saying it is a new replacement lamp (Phillips bulb). Read all the reviews and customers gave good reviews. Is the only way is to buy from Sony?
  • 5,370 Answers
Did you bought the original lamp or compatible lamp or second hand /refurbished lamp. If its compatible lamp then,in some cases the compatible lamp does not support.If its second hand/refurbished lamp then in some cases,the second hand lamp bulb are actually used lamp,so this lamp has very few hours left in it.In that case if works for few hours,but when this few hours gets completed the bulb explodes.---------- Confirm if you are getting brand new original lamp from sony.Get original sony lamp.Keep updated with the details.Thanks.Helpmech.
Posted on Mar 12, 2011
  • raj somaiya Mar 12, 2011
    Getting original lamp is much advisable.---------- Now why the bulb explode. Read this " When the bulb life come to end,at that time the indication comes on screen,that lamp replacement is needed.But still the same lamp can be used further for few more hors.As the hours gets less the second indication comes as lamp replacement is very much necessary.At this time lamp hours gets very less,so now lamp has to be replaced.If not not replaced the lamp gets exploded." So if the seller takes the lamp out when he gets first indication to replace the lamp,then it will works for few hours or may be few days then the bulb will explode.so in your case,most probably this has happened.When the lamp is original, it has full lamp hours and it last longer. Getting new original Sony lamp is advisable.----------- This should help.Thanks.Helpmech.
I replaced the lamp on the sony KDF E60A20 XL 2200U about 2-3 months ago and the lamp has blown out again. What is causing this to happen?
Three things can cause this.
1 Abrupt loss of power to the set such as a power outage while watching it.
2 A generic replacement lamp
3 A defective lamp supply ( ballast )
May 14, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
My tv comes on runs for 30 sec. then loses sound and picture for 30 sec. and the standby light flashes green for 30 sec. then the picture and sound comes on . then about 30.sec. later it does the whole...
It is symptom of weak lamp that has been reached to an end of its working hours life but not dead/ broke yet.
If lamp has not been replaced in last 2-3 years then please replace lamp in tv to get solve this problem.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 11, 2011 | Sony KDF-E50A10 LCD TV
I have 60" wega tv
This is indication of lamp is reaching to end of its working life and need to be replaced to solve this issue in tv.
Lamp replacement procedure would be written in user manual of tv and it is very easy, well explained.
Please buy Sony original lamp from nearest Sony store for good picture in tv.
Let me know if you have additional question.
Thanks.
Dec 21, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony TV, model no: KDF-46E2000, all of the sudden started shutting off randomly every couple minutes. It then takes between 30 and 60 seconds for it to reboot, or turn back on. This happens whether...
It is problem of weak lamp that has been reached to end of its working hours life, replace lamp in tv to fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Thanks.
Nov 27, 2010 | Sony KDF46E2000 46" Projection HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
(XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10: I have a KDF-E50A10. 4 years old. Lamp went out af...
This is by far the best xl2400 site ive come across so far. Has all the details as well as replacement guide and a direct link to amazon.com for purchasing...definitely check it out if you have any questions or concerns.
May 18, 2010 | Sony (XL-2400) Projector Lamp for...
Turns off/on every few minutes
I would replace the Lamp. This is a common symptom when the Lamp is failing.
I hope this helps,
Skyassoc
Oct 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Occasionally goes off and on. Picture is fine though.
It is Lamp that causing that error and turns TV Off and On again because weak lamp requires more current so ballast supply protection activated with lamp drive error code.
You should replace Lamp in TV and should buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
XL-2200 lamp for $200
Thanks.
May 02, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10 Logo
223 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
