Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 60pp9202 high voltage transformer
How much should it cost to replace this part on my tv. A guy told me $650?
  • MyPhillipsHD Oct 21, 2008
    Glad I found this. Was about to give up on my Beloved Phillip (different model of Phillips Rear Projection.) Repair company cost $60 to diagnose, and informed me it would be $500 to repair and they would have to take it away from me to repair in their facility.
    Now I'll fix it for less than $200. THANK YOU!
  • Philips Master
  • 8,617 Answers
You can get the HV Transformer at the following link for 132.00 which includes free shipping and free step by step instructions by online instant messaging so you can easily replace the part yourself. Very easy repair. The HV generator is listed under the flyback section yours is Phillips 32942 Flyback ( HV Transformer)
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 04, 2008
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
Screen does not switch on at all , and no sound either. However standby light is on only when plugged. TV repair told me it is transformer and line up, however asking for more then 100...
Hello, most common faults, such as CRT TV will not turn on. The reason stems from the low power supply failure, or from the high power supply. There are two transformers suppliers, with more common high-tension transformer goes bad. Price of 80 or $ 100, sounds reasonable replacement of transformer. Along with this need to perform some tests that require a professional, to confirm that the problem is due because of transformer. One test is to test basic stability, voltage power reaching the high-voltage transformer. If lower than normal voltage. Then perform the same test, when you break the initial snap of the transformer. If the voltage rises to the desired level must be to replace the high voltage transformer. Good luck!
May 12, 2011 | Sanyo Televison & Video
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
No picture - chirping like a bird
This is usually the flyback transformer (IHVT-integrated high voltage transformer) and the HOT( horizontal output transistor) The transistor will read shorted, with a multimeter, if it is bad. It is mounted to a heatsink straight back from the flyback. It may have a metal clip that holds it tight to the heatsink.
It is a pretty easy fix if you can solder.
While you have the board out, check for any discolored resistors and replace those as they will likely fail before long and cause more problems. Also check with a bright light and a magnifier for cracked solder joints and resolder any that you find.
Mar 02, 2010 | Philips 60PP9202 60" Rear Projection...
Spark
The black unit is the high voltage transformer and splitter and it has possibly cracked causing high voltage to leak out. Unless you have a heavy duty soldering iron and good with multiple solder connections, it may be best to have a technician check it out for you. I would guess it would cost in the $200-$300 range. Thanks for using fixya.
Dec 25, 2009 | Philips 60PP9202 60" Rear Projection...
Phiips model #60PP9202 -Green cast
Your CRTs need the coolant changed. Its a common condition in phillips models. You can get the coolant repair kit which contains all the coolant and the instructional cD that does step by step instruction with pictures of the entire replacement procedure
Aug 02, 2008 | Philips 60PP9202 60" Rear Projection...
My 60" Phillips HDTV Model # 60pp9202/17f chirps, no pic or sound.
This is a common problem with the Philips Tv sets. Get a repair kit from www.TvRepairKits.com.
Jan 11, 2008 | Philips 60PP9202 60" Rear Projection...
Sparks arcing from rear of tv
Wow they are charging you alot for this repair my friend. Go to this link and you will see! The High Voltage transformer, also known as a flyback only cost 50.00 Bucks!http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187762&ProductType=PART&ModelID=420798 I would get the part and let someone replace it If you have no soldering and or TV repair experience, as this is a dangerous place to be experimenting with if you do not know the safety issues involved. Good Luck Please dont forget to rate this thread.
Nov 25, 2006 | RCA D52W19 52" Rear Projection Television
Toshiba 35A44 - Dark picture on all channels and DVD's
for this brightness problem actually came out from flyback transformer...so, before you spend and waste your money, try to adjust at back of your tv first. But if you aren't an expert, better ask technician to do because that transformer supply a very high voltage....there's two adjustment point at flyback transformer, one point for focus and the other one for brightness! try first...
Nov 06, 2006 | Toshiba 35A44 35" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
399 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
