Question about Refrigerators
I have a Glen Canyon Beverage Center Model HDBC360D which has stopped cooling. I need a manual for this cooler. And I need informaion on how I can get it repaired.
Sea Breeze
  • 4655 Answers
SOURCE: beverage cooler not cooling enought
Jeremy, after the line and new filter drier is put in the high pressure side and silver soldered make sure the unit is placed in absolute vacuum for 30 to 60 minutes. It's critical that all air and moisture is remove and the charge applied on low side with out a single air bubble put back in. You may need some on hands help on this solution to get the cooler working properly, Thanks Sea Breeze
Posted on Oct 27, 2007
SOURCE: Beer Not Cold!!!
There is a temperature control knob on the back side of the ref. it is on the bottom by the compressor
Have you adjusted this?
clayfoot
Posted on Sep 27, 2008
SOURCE: Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Posted on Mar 02, 2009
i got it fixed. you have to know a little about wiring to make this happen, but not impossible. took cold control off old refrigerator, and wired it into compressor behind refrigerator. the cold control is no more than a thermostat that acts as an on/off switch, so the hot wire needs to be removed off the compressor and the hot lead on the cold control needs to be wired to constant voltage and the other wire on the cold control plugged into compressor where original hot wire was disconnected. you will have to drill a little hole through refrigerator somewhere to run thermostat wire off cold control into refrigerator. you now control the internal temp by the external cold control switch. if you hook it up this way you will only be bypassing the original cold control on the whirlpool, but will still have your digital readout of internal temp. mine now reads 32 deg. and if the beer is in the back of refrigerator it will have ice in it, just the way i like it.
bobicehouse
  • 1524 Answers
SOURCE: Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
Posted on May 20, 2009
Why isn't it cooling? GE Monogram Beverage Cooler ZDBC240NBS
Sara you question does not tell us a MAKE , or model perhaps you need to search the manufacturer's website for support .
Feb 15, 2016 | Refrigerators
Monogram beverage center model # ZDBC240NBS. Where can I get a wiring diagram and service manual?
perhaps the manufacturer but most will not give their service manuals out to the general public .
Feb 15, 2016 | GE Refrigerators
My beverage cooler MCBC58DST wont stay cool after it reaches target temp.
Throw it out and get another model from another company. Their units are junk!
They last a year, at best. Them and Magic Chef are one and the same...so you may have to bite the bullet and get a real unit.
Good luck. I speak from experience...I've had four now. Complete junk!!
Nov 23, 2014 | Vissani 5.8 cu. ft. Wine and Beverage...
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
Refrigerators Logo
342 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
