Help! My Adcom 555 amp and Adcom preamp is making a buzzing noise in one speaker - any ideas on troubleshooting - is it the preamp or amp?
    Brigadier General:
  • 8,546 Answers
Try a different audio source.
Disconnect the cable at the preamp end from the amp and see if it stops.
If it does = preamp.
If not = cable or amp.
Reseat cables at both ends with a twisting motion.
Swap left to right.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Lots of ways to eliminate sources of the fault and isolate the problem.
Posted on Mar 12, 2011
How to connect a yamaha p7000s amp to an adcom gfp-555 preamp
Use "Main Out Norm" from the gfp-555 pre-amp and connect to Canon connectors of the Yamaha. This requires a standard RCA to Canon cable for correct connection. Start with this first, if that works OK than try the "Lab" output of your pre-amp, but I am not sure if the Yamaha can handle this or the results of sound quality. Your choice.
Feb 17, 2016 | Yamaha Audio Players & Recorders
How do I eliminate buzz?
Things to check:
1. With your multi meter, measure from left ground to right ground. What do you get? Measure from each input ground to chassis. What do you get there.
2. Get or make a pair of shorting plugs. Plug those into the inputs. Power on. Hum there or gone?
3. Turn the pre-amp on. Connect. Level of hum change with preamp on?
4 additional information. How efficient are your speakers? This is a big amp, high-efficiency speakers may show some noise, while low-efficiency speakers won't.
A trip back to the shop may be indicated, too.
Nov 23, 2015 | Adcom GFA-5500 2-Channel Amplifier
I want to bridge 2 adcom GFA 555 amps to my sony DA7ES any suggestions
Obviously you are going to use the Front pre-out's on the Sony to drive the Adcoms. its pretty straightforward, just do not use a speaker that is less than 8 ohms. and make sure that you always have the power switch off on the adcoms, let them sit off for 5 minutes, THEN hit the bridge switch on the back of the adcom's and follow their instructions for bridging. it's pretty easy and tough to go wrong. Good luck...Rob
Apr 18, 2015 | Adcom GFA555 Amplifier
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
How to bridge GPA 555 adcom amp from 8 om to 4 om
First of all, when bridging an anp, the impenence that it can handle usually goes UP not down. I don't believe that the GPA555 can be bridged without circuit modification.
Dan
Feb 11, 2009 | Adcom GFA-5400 2-Channel Amplifier
Adcom input jack replacement
The input jacks on a 555 are a standard gold plated, high quality jack. looking around the net, you should pay no more than 7-10 dollars each ( or just get originals from Adcom. ). What is your comfort level with electronics?. Can you solder properly?. I cant answer this without more info.....thanks...Good luck...Rob
Dec 30, 2007 | Audio Players & Recorders
102 people viewed this question
 Grubhead
Grubhead
