I have a toshiba satellite a200 with a built in microphone, it says that's it it working but when i go to record my voice nothing is there. It is just static. Or when i'm on skype the other person can't hear me. I have done the audio testing on skype and it still does not work! What do i do to fix this, as much and as simply detailed as possible would be great! thanks
    Scholar:
  • 88 Answers
There are two main sources windows uses for Audio In (what you are trying to do) usually there is a Mic or audio in port (headphone jack) and there is a built in microphone. You may need to tell windows to listen to the built in microphone instead of the mic in port on the laptop. To do this right click the speaker icon in your system tray (down near the time) and click on Recording devices. If you are using windows 7 you will see your available recording devices with a sound bar next to them and you will see movement on the sound bar as you make noise. Just make sure you set your default device to the internal microphone here and you should be all set.
Posted on Mar 12, 2011
What do you do if the built in microphone for the Toshiba Satellite M305D-S4840 is not working (not picking up sound)?
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
May 20, 2012 | Toshiba Satellite M305D Notebook
I have a Toshiba Laptop PC. It is a Satellite Pro L300 Series. I wonder if it has a built in microphone so that I can add a voice/music clip to my power point slides. I do not have a separate...
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
Aug 18, 2010 | Toshiba Audio Players & Recorders
Does a Toshiba Equium A200 have a built in microphone?
Here are two different spec sheets for the A200-1V0 & A200-196. Neither one lists a "built-in mic" but both support external mics via 3/8 jack. Also there's always the possibility of using a USB mic.
A200-1V0
A200-196
Hope this helps, if so please comment, vote, etc.
Thank you.
Jun 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hi, my toshiba satellite A200-1Rk built in microphone is not working please help me to resolve. i installed drivers but only mic not working
Normally a problem with the mic isn't driver related unless you have no audio as well. What program are you using that the mic is not working with? More than one? Will the mic work in one program and not the other? If its not working in any of them, you may want to make sure the correct device is selected to record from in windows.
1. Start>all programs> accessories > entertainment > volume control
2. In the "master volume" panel select options > properties
3. in the mixer device drop down select the one that says input somewhere in the title
4. The check boxes below should now show you your options of devices to record with. Select the laptops internal mic and try using it again.
If that doesn't work there's most likely an issue with the hardware and you would need to replace the mic if possible.
Jan 14, 2010 | Toshiba Satellite A200-S18X01G Notebook
I disabled the microphone on my toshiba satalite
You can try these steps :
1. Goto Start -> Control Panel.
2. Sounds -> Recording.
3. Open the 'Microphone Properties' from the list of devices.
4. Change the status of 'Device Usage' to "Use this device (Enable)".
5. Apply settings and close the window.
tell me if it don't works...tc! :)
Jan 06, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba laptop Microphone Not working or Non-existant?
Click Start/All Programs/Accessories/Sound Recorder. Click Start Recording and talk to your computer in a normal voice. When you finish click Stop Recording. Type in a file name and click save. Open the file and play it. If it works you have a built in mike, otherwise buy yourself an external, which I recommend anyway, because the built in mikes are generally not good enough for voice recognition or VOIP.
Sep 22, 2009 | Toshiba (P000257700) Microphone
Does the Toshiba Satellite Pro 6000 have a
The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
Hope that helps
Chris
Jul 03, 2009 | Toshiba Satellite Pro 6000 and 6100 14.1...
Microphone not responding on Toshiba Satellite 2435-S255
Is your microphone built-in or external?
To test your microphone click on the record program to test it.
It is located in - Start - Accessories - Entertainment - Sound recorder.
Record your voice and play back to test.
Apr 09, 2009 | Toshiba Satellite 2435-S255 Notebook
Microphone of the Satellite A200-AH5
Right click the volume icon in the tray (bottom left) click recording devices- click the device you wish to use then click properties, and enable the device. then goto your chat/messenger settings and click the cam/audio settings,select the device and make sure somewhere in the properties/configuration its set to ALLOW OTHER PROGRAMES TO USE THIS DEVICE
Oct 21, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
512 people viewed this question
David Payne
David Payne
