Question about Brother SE350 Mechanical Sewing Machine
My problem is with the bobin. The machine worked well two days ago. Now when I try to sew , the bobin thread is becoming caught in the lower area and produces tension that stops the machine after about two revolutions. Even turning by hand to try to clear the problem after an error has stopped the machine I encounter resistance from the tension. It seems that when the thread make its revolution around the bobin case that it catches on something. I have removed the bobin and tried another, same result. I have taken the bobin case out and inspected it and find no burrs or scratches or any thing that looks out of the ordinary. Don t know what to do next.
  • 86 Answers
With out looking at the machine it is hard to determine the exact problem, but make sure your bobbin thread is placed in the bobbine case corretly, and pulled through the little tension area on the bobbin case.
Next make sure the upper thread is in the tension discs, if not this can also cause you a problem, plus if possible used a little canned air (with the pressure foot up, machine unplugged and thread removed) blow out the tension area.
Good luck.
Posted on Mar 12, 2011
Machine hand wheel will not move.
sounds like it jumped time . take it to a repair shop .
Dec 03, 2016 | Singer Sewing Machines
In my Janome Memory Craft 3000 my material got pulled into the area where my bobin thread comes from. I pulled it out. Now my needle is dragging but not breaking on the white piece underneath where you...
I would suggest replacing the needle, make sure the needle is correct for the fabric and thread being sewed.
sometimes when the fabric gets caught in the feed dog area, there are different reasons, I'll list some below
fabric is too thin--needs stabilizer
top thread has some off the thread take up lever
bobbin is turned the wrong way in the bobbin case
needle is damaged--replace needle with correct size for fabric being sewed--and insert the needle correctly into the needle holder.
if these suggestions don't help, I also suggest having the machine checked to see if there is some other problem like timing.
May 03, 2014 | Sewing Machines
My machine drops stitches, bobin hangs up, thread knots up. I have cleaned the bobin case and feeder. What can I do to fix the problem?
This may sound very simple, but try putting in a new needle. If the needle is blunt or has a burr on it, that could be the cause of your issues.
If it is a drop in bobbin style machine you may also have a "needle nick" on the plastic bobbin case. The thread can get caught up on those little knicks causeing it to get caught up or fray.
You can pollish down the little knicks with a very fine sandpaper to smooth them out.
Apr 21, 2011 | Elna 2007 Mechanical Sewing Machine
Lower thread breaking on lower looper ( green code) It won't sew over seams breaks everytime I rethread it
has the cone of thread at the back got caught up? this sounds like your thread is being caught and not feeding freely through the tension guides. Check the thread cones are okay and that the thread is pulling freely off the most right hand cone (lower looper). Also this thread dial should be set to the same tension setting as the next dial to the left for the top looper. Other possibility is that the tension disc itself has become gummed up or dirty with thread lint or dirt. Turn thread dial to zero and clean between the discs be rubbing the selvage edge of a piece of fabric between the discs gently. Now return tension to 5 or normal setting and try again.
Mar 28, 2011 | Janome MyLock 204D Mechanical Sewing...
My wife has a model 9110 sewing machine. It has stop picking up the thread from the bobin. Can you help on this fix?
Put new needle in
Make sure you have a 3-5 inch thread tail on both top thread & bobbin
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of machine & slowly lower needle into bobbin area & see if it will pick up the bobbin thread that way
rethread the bobbin,,also check the bobbin area for lint or loose threads
if none of these suggestions work, then the machine could be out of time & would need to be repaired
Nov 13, 2010 | Euro-Pro Sewing Machines
I have been sewing all day with no problems. Suddenly the needle is not picking up the bobbin thread. Why? Solution? Thanks!
the needle might be bent-roll needle on flat surface & see if it rolls correctly
if the needle is make a popping sound when it goes thur fabric the needle is blunt
check the bobbin area to see if there is lint or loose thread
check to see if the bobbin has become warped
the bobbin may not be inserted correctly in the bobbin case
check to make sure the bobbin case is inserted correctly into the machine
rethread the sewing machine in case the thread is caught somewhere
make sure there is a thread tail of 3-4 inches on both upper thead & lower thread
Sep 02, 2010 | Husqvarna Viking 1
My thread got caught inside where the bobin is so I took out the bobin and the thread was still stuck. I took out the 2 metal pieces that hold the bobin in place and now I can't get them back in. Help?!
Insert the small metal piece into the big piece. Try turning it in a circle one way. It should fall into place. It it doesn't, take the small piece, flip it, and turn again in a circle. It's very easy. Or go to ebay under bobbins so that you can see a picture.
Apr 06, 2010 | White Sewing 1866 Mechanical Sewing...
The bobin thread bunches up on the bottom side of garment.
Try these solutions.
* Re-thread your machine as it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 20, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
Frustration!!!
I have a Brother 270D too. I've had it for about four years and love it. It is a very picky machine sometimes and you have to treat it very delicately. I have had similar problems with the bobin in the past. Try removing the sewing plate by taking out the two screws that anchor it in. To accomplish this fhe first time, on my machine I had to use the flat head screw driver on my hubby's pocket knife because the screw driver that came with the machine had a handel that was too long to work with. After that, I kept the screws just tight enough to loosen easily with my thumb nail if I had to take them out, which I do on a regular basis. Now try removing the entire bobin case. Make sure your bobin case is not scratched! If if is, even a tiny scratch along the edge will cause major problems. This has happened to me, and you have to order a new one. I used an online dealer, spent $30 and my machine has worked great ever since. If your bobin case is not scratched, you are lucky and your culprit is most likely just fuzz or dirt. Try looking for any stray bits of thread that have gotten caught up under the bobin case or in the mechanisms inside the machine under the needle throught plate. If you had even one knot, odds are pieces of thread are still stuck inside somewhere. I use a can of compressed air to clean my machine on a regular basis and this keeps all the thread bits and fuzz at bay. You can also use the brushes that came with the machine and tweezers help too. Sometimes I just unplug my machine turn it uside down with the sewing plates off, and shake it gently. I am amazed at what come out! For some reason dirt seems to build up inside so clean it out regularly and you should have a much easily time sewing.
Sep 14, 2008 | Brother SE-270D Computerized Sewing...
Brother SE350 Mechanical Sewing Machine Logo
217 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
