Question about Gateway CX2619 Notebook
My Gateway laptop model CS2619 gets stuck on the Hardware Profile/Configuration Recovery menu and will not respond to keyboard commands. (yelling at it doesn't seem to work either).
  • 118 Answers
Reformat is an option
Posted on Mar 12, 2011
I cant get the program to reset factory settings
When the Dell logo appears, press several times to open the Advanced Boot Options menu.
Use the Arrow keys to select Repair Your Computer and then press Enter.
On the System Recovery Options menu, select a keyboard layout and click Next.
To access the recovery options, log in as an administrator and click OK to open the Dell Factory Image Restore menu.
Depending on your configuration, you may need to select Dell Factory Tools and then Dell Factory Image Restore.
Click Next to open the Confirm Data Deletion menu.
Select the Yes, reformat hard drive and restore system software to factory condition check box and click Next.
Nov 21, 2013 | AMD Gateway MX6445 PC Notebook
Gateway GT5404 Recovery Disk
You could have provided an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 11, 2012 | Gateway GT5040 PC Desktop
Dell vostro 200 F8 menu won't respond to repair
to access the recovery partition you need to press Ctrl and F11 when you boot up which should start the factory recovery process.
Nov 11, 2012 | Computers & Internet
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
Ok next question i need a recovery disc for windows vista for a gateway laptop please help me
You most likely can get a recovery disc from Gateway.
You can download the recovery disc and device drivers for yourmodel Gateway laptop from this WEB site. Make sure you select your model laptopand the correct Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Nov 06, 2011 | Gateway MT3705 Notebook
I have an HP620 laptop i just bought but i cant seem to get the hash and the @ button to work, when i press down the shift key together with either one of the above it just wont respond but i want to use...
hi Chrism938.
see if this helps you out.
HP Customer Support link.
https://support.hp.com/gb-en/document/c03843122
try the below instructions.
1.) Turn off the computer.
2.) Disconnect all connected devices and cables such as Personal Media Drives, USB drives, printers, and faxes. Remove media from internal drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, or power cord .
3.) Turn on the computer and repeatedly press the F11 key, about once every second, until Recovery Manager opens.
Recovery Manager:
4.) Under I'd like to identify any problems, click on Run Computer Checkup.
5.) Now select the radial button next to Open a Command Promt and then click on next.
6.) In the Command Prompt Windows please type and check the functionality of all the keys and check if B and N key works or not, if it does not then it's for sure hardware issue. So contact HP Techical Support and get the keyboard replaced/repaired.
7.) If it works fine in Command Prompt then, try creating a different User Account with Administrator privilege and check the functionailty of the keyboard.
8.) If nothing works out then please try system recovery(install Win7 OS) to set the NB back to it's Factory Original settings.
9.) Check the below link for the instructions to perform System Recovery:
http://support.hp.com/us-en/document/c01867418
or check this link out.
HP 620 laptop button not working Google Search
Dec 01, 2017 | HEWLETT-PACKARD 620 XT964UT Notebook PC
We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
(Use the arrow keys to highlight your choice.)
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: View a list of system recovery tools you can use to repair
startup problems, run diagnostics, or restore your system.
ENTER=Choose ESC=Cancel
Mar 18, 2011 | Computers & Internet
Gateway laptop computer freezes during system recovery
Turn the computer off, then start it back up and press the f2 key repeatedly til a blue screen called the BIOS screen comes up, press the right arrow on your keyboard so it goes to the advanced tab. go down to speedstop and disable it, press f10 to save changes and start computer over. Now it will work no freezing :)
May 31, 2009 | Gateway MX8711 Notebook
Gateway 7330GZ Not Booting Properly
Probably a virus, or your windows folder got corrupted. Try to use Knoppix (A linux distrobution that boots from a CD) to get all your data onto a pen drive or external hard drive. Download the Knoppix ISO at Knoppix.com and burn it onto a CD or DVD using MagicISO (magiciso.com). Insert the CD, and you should see the boot screen. Open the file manager, and copy all the files you want to keep from your hard drive to a pen drive or external hard drive. Then, reinstall Windows using a recovery CD (one might have come with your computer). Copy the files back, and PRESTO!
Feb 04, 2009 | Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
Gateway CX2619 Notebook Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
