Question about Maax Soprano II: One-Piece Shower Module W/o Roof Cap but with One Seat & M
How does the lift and turn stopper come out so we can clean plugged drain?
  • Shirley Fly
    Shirley Fly Oct 30, 2012
    I HAVE TRIED this I can not get the top knob OFF...just the very top knob or the entire unity????
  • 528 Answers
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Posted on Mar 12, 2011
    Clogged drain on moen bathroom sink
    There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
    The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
    If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
    Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
    Grohe drain stopper installation
    Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
    clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
    Jan 20, 2014 | Plumbing
    Water is draining from hot tub after its filled & dont know why
    Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
    Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
    I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
    Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
    Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
    We have a delta tub stopper that lifts straight up and does not turn. We need to remove the stopper piece to take care of a blockage in the drain. How do we get the stopper out?
    Hold the stopper and unscrew the top piece and u will find a screw and if not this style it should turn with a little extra fource...Hope this helps.
    Aug 11, 2010 | Home
    Removing bath drain
    There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
    Lift and Turn:
    The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
    Toe Tap:
    The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
    If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
    This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
    Apr 09, 2010 | Delta Home
    Pop up raises only partialy, pop up not square in drain
    YOU CAN TRY BY ADJUSTING THE ROD ,UNDERNEITH THE SINK ,MUST POP-UP ASSEMBLIES,HAVE A ROD COMING OUT OF THE DRAIN AND A ROD WITH SEVERAL HOLES ON ,IT TO ADJUST HOW FAR YOU CAN PULL THE ROD UP ,WHICH IN TURNS SHOULD MAKE THE STOPPER GO DOWN,ALSO A COMMON PROBLEM IS THERE IS TO MUCH HAIR AND TOOTHPASTE STUCK ON THE STOPPER ITSELF,SO SIMPLY UN SCREW THE NUT, THAT IS HOLDING THE ROD INTO THE DRAIN ,THEY LIFT UP THE STOPPER,THE STOPPER SHOULD NOT BE ABLE TO BE REMOVED WITHOUT TAKING THE NUT AND ROD OUT ,IF SO YOU MIGHT HAVE TO REPLACE THE WHOLE POP-UP ASSEMBLY
    Mar 17, 2010 | Plumbing
    Tub drain wont stay open
    If this is a trip lever waste type of drain it can be adjusted, Remove the 2 screws that hold the adjusting lever, this will allow you to remove the stopper. Clean the stopper of hair and sludge and replace. This will usually fix the problem. If not then adjust the linkage for the stopper.
    Nov 23, 2009 | American Standard Scala Bathtub Only ...
    I can't get the drain plug off from it's base. It's supposed to be able to unscrew, it just spins. It's a Kohler tub. Does anyone have a clue?
    Is it a lever handle drain or lift and twist lift and twist there is a small set screw on the popup you need to look for it on the stopper post only loosen it until you can pull off stopper or screw will fall in the drain
    Nov 09, 2009 | Kohler 1257-GLA-0 Mariposa 6'...
    Delta pull-up bathtub drain problem
    Hi Bigoz,
    Drop the drain plug down about half way and try turning it counter clockwise. If you get no resistance after a full turn you will probably need to cut or break it out. If the pin is missing I'm guessing this is what you'll have to do. This answer assumes you have a lift and turn style drain.
    Please ratre this response and Good Luck, Phil
    Jan 01, 2009 | Delta T13420 Chrome Classic Single Handle...
    Maax Soprano II: One-Piece Shower Module W/o Roof Cap but with One Seat & M Logo
    1,225 people viewed this question
    Top Maax Plumbing Experts
    Donni Steen
    obsteiner
    Andrew Taylor
    Andrew Taylor
    Are you a Maax Plumbing Expert? Answer questions, earn points and help others
