Question about Mongoose 24" M Estes Bicycles
Rear sprockets free wheel on rear wheel almost as if disconnected-new bike
  • 827 Answers
It's not uncommon.,. perhaps shoddy assembly. There is a small thin nut which once you dismantle it all apart, you can tighten. Be careful not to have the assembly come apart as it is a headache when you don't have an eye for how it all goes together...
Best regards
Ck
Posted on Mar 12, 2011
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
The chain is broken off the bike We bought a new one but need a diagram of how to weave the chain through Thanks
The chain goes from the top of the front sprocket to the top of the rear sprockets, between the rear sprocket and the top derailleur wheel and then between the upper and lower derailleur wheels. It then goes forward toward the front sprocket. The text sketch below shows the rear sprocket, chain and derailleur.I hope this helps.
(O
o)
(o
Aug 15, 2011 | Pacific International Pacific Evolution...
Crackling sound in the chains while driving and something sound like a tambourine somewhere in the rear brake.tnx
It sounds like the bike needs a new chain and probably new front and rear sprockets as well. The sprocket teeth should have a rounded blunt end. Do the replacement of chain and sprockets and then see if the tambourine has gone away. If not, I would dissasemble the rear wheel and brake for inspection. Loose or broken parts, wheel bearings gone bad or brake assembly problems may be present. Please rate my answer. tombones49_195.gif
Jun 23, 2011 | kawasaki ZX-12R Motorcycles
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
May 25, 2011 | Razor MX500 Dirt Rocket
The sprocket on the rear wheel is frozen. The bike cannot coast as the petals keep turning when the rear wheel is turning.
If I were fixing this problem, the first thing I would do is soak the sprocket with WD-40 or CRC. After a day, gently tap the sprocket in an attempt to free it. Soak it again and so forth. If it doesn't come free in a few days, it may be better to replace it. What condition is the chain in of the rear sprocket is frozen to the wheel?
Thanks for your interest in FixYa.com
Feb 10, 2011 | Cycling
Can you change tranny gears to decrease rpm's on highway? Or maybe change sprockets.
You can add teeth to the front sprocket or take teeth off of the rear sprocket. In the case of your bike , I do not think there is a 17 tooth front available so your best option would be to shorten your chain and drop from the 44 tooth rear sprocket to 40 tooth or a 36 tooth rear sprocket. That would be like adding one or two teeth to the front sprocket. Your stock is 16/44 so decrease from there. Be sure to ID your chain, get a chain breaker, and a new master link.
Feb 06, 2011 | 2004 Honda VT 600 C Shadow
My son just bought a 26" Huffy Jolt mountain bike. The rear sprockets spin freely when the pedals are cranked either forward or backward - - that is, there is no coupling to the rear wheel. What can I...
The plastic is to stop the chain from touching the spokes, it cannot cause this problem, either the chain is not on a sprocket correctly or the rear cluster(sprockets) is not working.
Some spray lube may help, but if it is new, take it back to the shop.
Apr 18, 2010 | Huffy Mens Mountain Bike - Crimson Red
Can you tell me how to change the chain and sproket on a '07 Honda Shadow VLX 600cc???
I don't have any experiance with your particular bike but have changed them on many different bikes to date. You should first purchase a new chain and sprokets and compare them to the existing one prior to removal as you won't be able to refit the old one safely. You are checking for the correct amount of teeth on the sprockets and the amount of links in the chain.
Once satisfied that you have the corrrect parts. Remove the front sprocket cover and locate the front sprocket. Most large bikes will have a large nut holding it on. Smaller bikes will use a tab washer and or circlip. If you have a large nut i find the easiest way to loosen it is to put a lock or similar through the rear wheel to immobilise it and then with a breaker bar loosen the nut. Once free change the sprocket over, then move to the rear sprocket loosing each nut in turn but making sure you are appling pressure to the nut squarely as it is easy to cross-thread these smaller nuts. This is best achevied by leaving the wheel on the bike until all the nuts are free. Remove the wheel and change the rear sprocket. Once done you are now ready to remove the chain from the swing arm. You can either cut it off with an angle grinder or you a chain link tool as i do.
Now the chain is split. Connect the new chain to one end and feed it through. Detach the new from the old and then rivet both ends together using a chain tool as described in the tools specific instructions.
Regards
Chris
Nov 06, 2009 | 2005 Honda VT 600 CD Shadow
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
May 10, 2009 | Razor MX500 Dirt Rocket
I am new to motorcycle, how do I take the rear or front wheel out
put bike on motorcycle lift and secure. take off exhaust silencer on right side.remove rear caliper from swingarm. jack bike carefully,loosen axle nut and pullout axle.remove chain from rear sprocket.drop wheel down & back.
Feb 08, 2009 | 1988 Honda CBR 600 F(1)J
Mongoose 24" M Estes Bicycles Logo
168 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
