Question about Frigidaire GLTF1670A Front Load Washer
Elextrolux model number GLTR1670ASO. What is the capacity?
Elextrolux EWF168540 W TimeManager 8kg stopping mid program without any error message
The recurrent problem may be due to a defect in the Time Manager.
Feb 01, 2017 | Washing Machines
Elextrolux smell stinky
Good Afternoon Anonymous, thank you for your inquiry!
I see that your Electrolux appliance has a stinky odor. Please help me understand if you are speaking about an Electrolux refrigerator? If so, where is the smell coming from? Is it located in the crisper drawers? Also, may I please have your model number? You can typically locate the serial tag (which provides your model number) inside the cabinet, on the left or right side wall. With this information I can assist you better in pinpointing the problem. Thank you! - Z
May 24, 2014 | Electrolux Refrigerators
Elextrolux french door fridge turns on and off and says power failure.
what is the model number?
Here is a little trick to try first. Get an alarm clock that has a LED display. Plug it into the same outlet as the refrigerator and leave it over night. In the morning, check to see if the clock is flashing. Post back the results.
Feb 06, 2013 | Electrolux Refrigerators
Elextrolux code ELE
The model number you have submitted to us is incomplete or not correct for your unit. In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Apr 14, 2012 | Washing Machines
I have an elextrolux icon e30df74eps and i think that the control board is bad. I have the part but it seems like i have to disassemble the whole range to replace it. Is that right? Is there a manual...
this is the schematic for your entire machine http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Model-E30DF74EPS/1412/0122007?pathTaken=&prst=0&shdMod=E30DF74EPS part number 26 in this next diagram is this the board you are trying to replace if so here is also the diagram to that specific area blown up so you can see how to access the board http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0606024-00001.png if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Apr 01, 2011 | Electrolux Kitchen Ranges
Elextrolux Range stuck in Demo Mode
Phone agents and ask for workshops. Quote them the model and problem you have.
Jun 06, 2010 | Electrolux 30" Self-Cleaning Slide-In...
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Hinch for Freezer/Fridge doors is broken,Kelvinator/fridge Freezer Model Opal-N520F-L My address is 30 Murraba Crescent, Tweed Heads 2465, NSW Where can I get the part
Thanks for the reply,
I solved the problem by finding an old warrent card with aphone number which I rang and was tild a nother number and that Electrolux is holding parts for Kelvinator, the nearest Electrolux branch for me was at NERANg a 30 minute drive. Their had the spare part for $20 and I replaced the hinch with a spanner. All is well as good as new.
Amazing how would one know that Elextrolux is holding service parts for Kelvinator, Westinghouse and others, unbelievable really
regards
Ziggy Mireis
Jul 06, 2008 | Refrigerators
Will not extract on spin cycle
After oheming motor control board as stated in the service manual. Tracing the 6 pin lead wires from the control board to the motor plug. I found that one of the pin on motor plug was not making proper connection. I used a screw driver to pry the pin open so it made a better connection. Tried the washer and so far it has been working 7 washes.
Mar 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
141 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
