Question about Sony Playstation 3 (PS3) Console
40 gb model Data is corrupt error trying to update. Have tried updating online and with memory stick, thru update screen and thru safe mode with same results - Tried wit ver 3.56 then with 3.6.
  • 4 more comments
  • bhoppy614 Mar 12, 2011
    It stops at 62%
    It is not under warranty. I can still play blu ray disks sucessfully.
    Thanks - i will give it a go
  • bhoppy614 Mar 13, 2011
    I have tried reformatting. Still it stops at 62% when trying to run an update.
  • bhoppy614 Mar 15, 2011
    Thank you - i gave up and sent the unit for repair
    Thanks for your help - I tried a BlacX usb to SATA dock but it would not see the PS3 drive. - I gave up at that point and sent the unit out for repair.
    Genius:
  • 1,622 Answers
Hi, when Updating play stations,You are expected to use the right version for update. Most times people use lower versions,while some other people use higher version that is higher than the play station they have..
So make sure the version you are trying to install or use for the update is not higher than the version your using at the moment.
You can use the link below to know more about firmware.
blog.us.playstation.com/2010/03/28/ps3-firmware-v3-21-update/
Thanks ......
Posted on Mar 13, 2011
  • Sony Master
  • 13,433 Answers
Hello
Format your ps3 and try again.
Settings > System Settings > Format Utility > Format Hard Disk
Doing this will delete all your data, including all game saves. Back up what you want to save before proceeding.
    President:
  • 1,139 Answers
Can you tell me at what percentage the installation of the update fails? This will help greatly in solving your problem.
Many thanks
Posted on Mar 12, 2011
  • 1 more comment
  • Kevin Penn Mar 12, 2011
    Ok, this is usually due to a faulty blu ray player if it stops somewhere in between 60-70%. There is a long and lengthy solution to fix this but it involves taking apart your PS3 and stripping it right down to the motherboard. Is your system within warranty?
    Ok, I will give you the information anyway, see how you feel about trying it -
    What you have to do is strip your ps3 right down to the motherboard. On the motherboard is a battery which is basically the systems memory. Remove the battery and short the terminals of the battery holder together. Follow this guide for disassembly instructions :
    http://www.llamma.com/PS3/repair/PS3_dis...
    Once you have done that, put your PS3 back together by working in the opposite way to the guide.
    Now you need to prepare your hard drive. Connect it back up to your computer. Goto control panel -> administrative tools -> computer management. Then click disk management.
    Your PS3 drive will be listed in the drives at the bottom of the disk management window. Now this one is a little hard to explain. The letter of the drive and drive information is listed in a square box. It may say "Uninitialised". You have to right click your mouse in this area where it says this. You should see an option to initialise disk. Do this. It basically turns your drive back on. After this on the right of the area where it said the drive letter it should now be a longer box with "Unnalocated space". Right click this area and select "Create simple volume". Go through the options but MAKE SURE you do not have a tick in the box that says "Format Drive". You must not format it.
    After it has created a simple volume the disk should be listed as "RAW data".
    Next you need to download the latest update to USB memory stick.
    Put the hard drive back into the PS3 and go back into the recovery menu as before. Select system update. Follow the instructions to install from external media.
    The following information is just as important to get right. If you do not get it right you will have to start at the beginning and take the PS3 apart again.
    Right before the point where the update is failing, in your case 68%, remove the hard drive. The installation will stop and an error will come up with a countdown from 60 seconds. Let the countdown finish and the PS3 will restart. When the PS3 retsarts the screen will be blank, replace the hard drive.
    After about 30 seconds to a minute the console should come up with a screen saying the hard drive needs to be formatted. If you get this then the procedure has worked and your PS3 should be brought back to life.
    The reason this happens is normally due to a hardware failure, usually the blu ray drive. The update checks to make sure that everything is working properly.
    If this procedure does not work then you unfortunately have irrepairable firmware damage which is going to have to be sent to Sony to fix.
    Hope this helps and let me know how you get on
    You will need a USB to SATA cable for this to work properly
Lcd screen goes black
Try to start your computer in safe mode by press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your deivers . just go the site of your Laptop manufacture. Once there enter the model number of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
If this is helpless then simply get the Reginout to fix all the errors and corrupt registry which made this annoying issue
Jun 23, 2013 | ASUS Computers & Internet
Ps3 error 8002fb27
this particular error is caused by corrupted data easiest way around this will be to install the update via a usb flash stick.
you can download the update here http://uk.playstation.com/ps3/support/system-software/detail/item541668/Update-features-%28ver-4-31%29/
this link will explain how to update via a Usb stick http://www.ps3news.com/forums/ps3-guides-tutorials/how-install-ps3-firmware-memory-stick-99095.html
Please only use the first to download the firmware only ever trust official sources.
Dec 04, 2012 | Sony Playstation 3 (PS3) Console
I have a dell optiplex gx280 and i turn on the computer and it tries to start windows but thengoes to a light blue windows screen and it says that it is checking file system on c. It does a chkdsk and then...
If it looks like this picture, What your seeing is colloquially known as the 'blue screen of death.' It usually means that whatever kind of corruption is in your file system is only repairable through a full format. But first follow these steps:
If you are able to access the BIOS menu (usually holding down either F2 or F12 on startup) try booting in safe mode. If that has no success, try booting from your operating system disc. This problem is common in old computers and is a sign of the end of its life-cycle. Consider purchasing a newer model.
Jul 19, 2011 | Dell OptiPlex GX280 PC Desktop
I am trying to use a USB stick in safe mode to update the system software on my ps3 to 3.50. im doing it this way because it will not update via internet without stopping and encountering error 80710723. i...
The fact you're using a Macintosh system should have absolutely no bearing on your memory stick displaying the data for your PS3 to see. What may be the cause, though not very likely, is the format of the memory stick itself. You must first make sure you didn't accidentally change the format from FAT32 while saving the update to the storage. Another possibility is that memory stick may not have been formatted as FAT32 to begin with, which isn't very likely.
Check this first before continuing on. Once this part is settled, or if there are no changes necessary, proceed to the next section.
The next thing you must do is properly and immediately back up your game and save data before applying the update just in case something goes wrong. Once you've completed this part DO NOT enter safe mode again, instead, allow your PS3 to start normally and load all settings and data before proceeding to the next step.
From this point go to Settings > System Update > Update via Storage Media. Press X on the next screen when the system "sees" the data, accept the User Agreement, then start the system update.
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
Last windows update now I can't boot it up. Window screen comes up and then shuts the computer down and statr all over again
Ensure NO media is plugged in first ie CD / mem stick.
May not be the Windows update. try booting into safe mode using F8 key, if you can access windows that way then problem is a program thats trying to load. To stop programs from loading go to safe mode
If windows wont load in safe mode then registry is corrupted.
Jan 26, 2010 | Toshiba Satellite A85-S107 Notebook
Ok I'm denise my problem is I get a blue screen telling me A problem has been detected and windows has been shut down to prevent damage to your computer If this is the first time you've seen this...
The Blue Screen of Death. Yes, I have had it many times. You can try to restart the computer using the F8 to enter safe mode. Then shutdown and restart. This usually happens when a file has been corrupted, normally by a virus or improper shutdown. If this doesn't repair the problem your left with trying to re-install the OS to fix the bad file. If yo can't get to safe mode your only option is trying to re-install the OS. If you see an option to install or repair choose repair to get the machine back up. I saw this a lot with ME, if you have Windows ME, get Windows XP and upgrade since Windows ME has so many bugs that XP would be a much better option.
Sep 12, 2009 | Computers & Internet
I am not able to open my memory stick of data traveler 40 gb
Dear,
You can do then please
!. Check the same Memory Stick on another PC (if possible then of same configuration as your PC)
2. Make sure your Pc has Updated antivirus.
If both are Ok then follow the steps
1.Backup the Memory Stick data on other PC.
2. Format the Memory Stick.
3. Paste the data back to the Memory Stick.
It will solve your problem.
Regards,
Rakesh Kumar
Apr 03, 2009 | Electronics - Others
How to i update my psp & my psp not suported the video....give an
you can go to the nearest gaming store to update a new firmware. pls remember not to download any firmware update from the internet, this will corrupt your console. Mostly, internet firmware update are not safe.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Slim...
BSOD- STOP error message
most bios updates are found on the compaq website, they need to usually uncompress to a 3.5 floppy or they are auto-installing programs u get from the website, your issue however sounds to me more like a corrupted version of windows, did you try a fresh installation with the recovery cds or master disks?
Aug 12, 2008 | Intel Motherboard
BIOS update
1. Check your PC or motherboard manufacture for BIOS upgrade and upgrade BIOS firmware.
2. Try to start your PC in a safe mode by pressing F8 before windows starts. Then select a safe mode with or without network support.
3. If your computer starts in the safe mode, check if your hard drive is not full or close to full. If it is close to full you need to remove some data from your disk. Try to remove temporary files and clear your Recycle Bin. Restart your computer.
4. You might run low on your memory. If your PC doesn't have enough physical memory, windows is creating virtual memory by using space from your hard drive.
5. If neither solution works, try to run a "CHKDSK C: /R" from recovery console.
Good luck!!!
Jun 11, 2008 | Umax Computers & Internet
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
