Question about Summer Infant 02580 Color Flat Screen Video Baby Monitor
The monitor is not working with the camera. The screen indicates there is no signal but the instructions do not tell you how to correct this.
    Genius:
  • 1,157 Answers
Hi Rebeccaluna2,
If the monitor is not working with your camera it might caused by the configuration. There are some ways on how to set up the monitor, either you check the selector/switch or check all physical connections. Here are some steps that you can apply on setting Up the Summer Baby Monitor.
1. The camera has long power cords, so just plug in the camera.
2. Now it has two channels A and B. Just move the selector switch to your desired channel.
--> for this steps just select Channel A.
3. Then set up the flat screen monitor where you want it. Plug it in, then move the selector switch to channel A.
--> The video monitor has several controls like video on/off and power. So please make sure that the monitor video and power is turned on.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 12, 2011
Monitor screen lights up for only a second then gives "No Signal Input" error message. I've rebooted both the computer and unplugged the monitor to start to no avail
Have you tried plugging the monitor to a different computer? This will tell you if the monitor is bad if it works correctly in another computer then most likely your video card has gone bad and needs to be replaced.
Jul 11, 2011 | HP Pavilion Slimline s3700f PC Desktop
My monitor screen is black. The green light is on but black screen
The green light usually indicates that the monitor is getting a signal.
The lack of a picture is an indication that the monitor itself is having a problem. I would test the signal with another monitor if you can get one.
I suspect that the monitor backlight has gone bad (if so, you can see the screen very faintly if you shine a light on it).
Or, the screen circuitry has gone bad.
Jun 30, 2011 | Computers & Internet
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
Jun 24, 2011 | Pyle PLCM7200 Car Monitor
No signal. Power is on, cable functions well (tested on other computer). nevertheless, the screen does not work (any more) and shows signa " no signal" . What can have gone wrong with my screen...
The fact that you see the "No Signal" message indicates that the display is functioning properly. The problem is with the input section. Verify that you have the correct input selected. Other than that, the input board is the likely defective section. This is not uncommon and will require service. This is not likely to be a DIY repair if the input board is defective.
Dan
May 29, 2011 | iiyama Prolite E430 17" LCD Monitor
Had summer baby monitor for eight months, last night it stopped
Your monitor has become unpaired with your camera. Follow the instructions in the manual to pair them again (basically, tell the monitor piece to Add New Camera while you press the Pair button on the camera). The manuals can be downloaded from www.summerinfant.com.
Jul 08, 2010 | Summer Infant Day & Handheld Video...
Need to shut off blinking indicator light. I know the 3 blinking light means the backlight or inverter is going/gone. The monitor is old, so I am okay with this.. But is there any way to turn off the...
No, this is a built in indicator in the electronics to tell you that the florescent tube and or the inverter is not getting proper signal and is have an issue adjusting the brightness or controlling the image to data to the screen.
In other ways you need to service the monitor. It will work another few year if you do it no.
Jun 18, 2010 | Apple Cinema HD Display30" Flat Panel...
EOS 1000D Incomplete boot. No visuals on screen, BUSY signal in view finder. Sometimes, the flash will fire.
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jan 20, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
No signal
Start the pc in SAVE MODE to do that kep  F8 at the startup and than change size of the screen.
Jan 18, 2009 | Acer X173WB Monitor
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
Summer Infant 02580 Color Flat Screen Video Baby Monitor Logo
387 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
J.D. Browning
J.D. Browning
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
