I was doing a normal load of towels and I got the ld error at the 9 minute mark. Now I cannot get the washer to function. At most it will fill water for a bit no matter which cycle I choose.
Yes at the 7 to 9 minute mark is where all the water should be out and the spin cycle progress to finish, sometimes water in tub causes vibration and error codes of oL and the like. Mostly with Oasis and with some front loaders the drain hose can set for a slow drain which is not detected until lint and other small particles start clogging the pump and sometimes the drain. I first check the drain hose to make sure I hear water gurgling as it drains ensuring no back pressure to slow drain. The second one is stuff in the pump and this machine has two pumps. Get a healthy gentleman to tilt the machine back for you so you can examine the pump on the right side. This is the drain pump and the larger of the two. Get a deep flat tray like a oil pan because were going to get wet pulling the hoses off and looking in the pump for debris. While we are here check the exterior hose going to the drain for lint build up.
I'm having the same problem with my machine which is less than 1 year old...or really close. I took out half the close (was a small load already) and then ran the rinse cycle again (seemed to be the shortest cycle) and then the washer completed the spin cycle. Did the same thing to get the second half of the load done. The error code associated with ld is "taking to long for the load to drain= ld. Not sure why this is happening. Do you have any add'l info?
