Question about AOC Monitor
New AOC monitor. No sound . when i insert dvd which was in the package it just promotes AOC products
    Scholar:
  • 88 Answers
Did you plug the sound sable into the audio out port on your computer?
The VGA and DVI monitor cable/plugs do not have sound capability so if there are speakers on your monitor they need to get the sound signal through a separate wire.
HDMI can send sound so if your monitor is hooked up via HDMI it should be able to pass sound as well (at least in most circumstances).
Posted on Mar 12, 2011
  • 3 Answers
I just picked up one of these monitors second hand. It's an AOC N19W and got it for just a few quid as although the screen is perfect, the "speakers didn't work".
I simply connected it up and yes they were not working. I went into the on screen menu, selected the sound options pressed mute then unmute, then tuerned the volume level right down and when I turned it up again the sound came back up with the slider!
Hope it helps
Posted on Dec 21, 2012
My Monitor has no sound
If your monitor is the AOC 2036sa then it does have built in speakers. It should have had a cable in the box that would go from the PC to the monitor. If yours did not have the cable or you misplaced it then you will need to get a new one, they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=176
Nov 15, 2012 | AOC 2036sa 20"TFT LCD Monitor
Replaced ph monitor with aoc,no sound. do I need seperate speaker/s? my hp had port for sound cable from computer,aoc does not.?.
attach speaker on to the green port on the back of the cpu, then play sound, before this also check whether the sound driver is installed or not in device manager
Jul 29, 2011 | AOC Monitor
My aoc monitor 2216sw shut down after three seconds on
It sounds defective. When the high voltage power units stop working; you will experience this type of problem. I would call AOC and see if the monitor is under warranty. Otherwise, seek an alternative monitor to use.
Jan 06, 2011 | AOC 2216SW Monitor
What made aoc and meaning aoc products
http://us.aoc.com will take you to the companies official website. On opening this website, on the bottom left hand side of the screen you would click on ABOUT AOC. Here they explain their company, of the left hand side you may click on the other headings for more information.
If you feel that I have misread your question, please comment below and I will be happy to assist you!
Thanking you
damnor01
Dec 11, 2010 | AOC 2036sa 20"TFT LCD Monitor
Monitor has stretched images. I use CAD programs that require equal vertical & horizontal. I am using only a VGA cable plugged into my HP Pavilion. AOC suggests DVI cable, but did not include one...
You should set your PC video resolution to the native resolution of this monitor: 1920x1080 at 60Hz . Right now you do not have it set to the correct aspect ratio for this wide sceen monitor.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 28, 2010 | AOC F22 Monitor
I need a manual for a 22" AOC monitor
Suggest you go to AOC Support, Downloads>Manuals, and type the exact model of AOC monitor that you have.
Download the User Manual.
For example:
http://us.aoc.com/support/downloads
Product Category:
Left-click on the blue down arrow, to the right of this box.
Left-click on LCD Monitors
Model Number:
Left-click on the blue down arrow to the right of this box.
Scroll down, and left-click on the model number of your AOC LCD monitor.
After you have done this, a drop down menu will appear.
Where it states your monitor's model number, and the word - MANUAL, go to the right, and click on the white - Download.
The User Manual is in PDF file form. Give it a few seconds to download.
Jan 03, 2010 | Computers & Internet
Same problem--AOC monitor "goes to sleep" after an hour online
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 09, 2009 | AOC 19LVWK LCD Monitor
Help me instal aoc mod.tft19w80ps monitor
yes you first connect monitor then insert cd came with pc wait window will open select vga driver option it will be installed then switch on pc
Nov 20, 2008 | AOC LM742 17" LCD Monitor
AOC 15' LCD TV
go to local radio shack
http://www.radioshack.com/product/index.jsp?productId=2103894&cp=&sr=1&origkw=computer+power+cord&kw=computer+power+cord&parentPage=search
Dec 10, 2007 | AOC A15X221 15 in. LCD Television
Computers & Internet Logo
2,331 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
