Question about LG WM2233H Front Load Stacked Washer / Dryer
It has a horrible odor. Also the little door on the left bottom front of the machine holds water. How do you keep the water (stinking) from standing in that area?
  • 4,070 Answers
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
If the standing water is your fabric softener you'll have to clean it out to unstop it so it will drain.
Here's a DIAGRAM which may help with the cleaning.
Posted on Mar 12, 2011
  • Karl Whisenand
    Karl Whisenand Jun 05, 2014
    switch to vinegar for fabric softener , run the cycle for the hottest an cleanest you can find . boil some water an toss it in there with some oxiclean or ammonia but not both at same time, watch for fumes .
How do I stop the old water smell (earthy odor) in my LG front load washer?
All washers keep a certain amount of water in them, though front loaders, especially the newer ones, are prone to odors. This is because the are more energy efficient and use less water. That can result in more residue being left behind on the outside of the wash drum where you cannot see it or access it to clean. Some things that are helpful:
  1. Do not close the door of the washer after use. It will allow the interior to vent and dry out, reducing odors.
  2. Use only the recommended detergents, and in the amounts recommended. Many people use too much soap in HE washers. A tiny bit goes a long way.
  3. Use a front loading machine cleaner - they are sold in most grocery stores. These help clear the residue from the drum, reducing odors.
Sep 01, 2015 | LG WM-2277HW Front Load Washer
I have a 7 year old LG WM2277....that stinks like crazy!.......So I removed the Water Circulation Nozzle inside the washing machine door at the top of the grey rubber ring. I did this with the intention...
The easiest way is to remove the top panel of the machine. There are 4 screws in back that hold the top of the washer. Remove the bottom screws and push the top rearward to remove the top. You can access the hose from the top and reconnect the hose.
Good luck
Jun 16, 2011 | LG WM-2277HW Front Load Washer
My washer smells horrible. The clothes after being washed smell horrible. I have left the door open. I have run bleach thru there 2 or 3 times in a row...didn't help. Have also run baking soda thru...
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting rid of a horrible stink in my washer kenmore HE2
The following link will give you some tips to try in order to minimize odors and mildew in a front loading washer:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Following a good regiment of routine cleaning of the door bellow, followed by leaving the door open when not in use (at a minimum) can go a long way towards preventing odors in a front loader. Since the doors on these washers are water tight when closed, it is importnant to leave them open when not in use to allow the drum to air out. There is a small amount of residual water that remains in the drain lines and pump that will sour if you don't. I personally own a Kenmore Elite and have never had problems with mildew or odor in the 9 years I've had it by following this routine.
In addition, it is a good idea to periodcially check the drain pump reservoir to ensure there is not dirt or debirs clogging the pump and becoming stagnant. The following link explains how to access and clean the drain pump (if necessary):
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
The drain pump reservoir collecting debris, along with small articles of clothing getting caught in the folds of the door bellow are the two main causes of odors in a front loader.
Read through the links provided and let me know if you have any questions. I hope this helps you.
Feb 05, 2010 | Kenmore HE2 Plus Front Load Washer
Horrible mildew odor in the washer. Find that this problem is common as I searched for a solution. How can we get rid of this odor? Have left door open after laundry and it does not seem to affect the...
Check the pump.. the little door bottom left. take all the stuff out of there.. and there will be lots of "stuff". put a little pail under the hose part to catch the water first though.
Scrub the machine with three tablespoons of cascade dish detergent in the SOAP dispenser.. use a hot wash.. ( no clothes JUST a wash ) then follow that with one cup of bleach in the SOAP dispenser.
Hot fast wash. Usually this clears up the problem. Do this once a month.. but check that little door..
Nov 28, 2009 | LG WM1812C Front Load Washer
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
I have a Duet washer with a severe odor problem. We keep the door open when it is not in use. We have tried the Affresh tablets with no success. I am currently running a bleach cycle weekly, and it only...
The Duet has a filter trap that's pretty easy to clean. There could be debris catching residue and not allowing the washer to drain right. Remove the toe panel with a torx bit and turn the filter handlt to the left. Have towels handy because there is always a gallon or two of water left in washers after they drain! Cleaning the filter trap should be regarded as regular preventive maintenance.
Leaving the door open will actually make the problem worse because it dries out the odor-causing residue and makes it much harder to remove. If your washer stinks with the door open or shut it's time for a good cleaning before it gets worse! The area of heaviest buildup is always between the inner stainless tub and the outer plastic tub. After your washer has been cleaned you'll need to change your washing habits so odor doesn't return. If this doesn't remove bad odor you'll need a good washer cleaner.
To compare washer cleaners watch this video
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 12, 2008 | Whirlpool Washing Machines
LG WM2233H Front Load Stacked Washer / Dryer Logo
182 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
