Question about HP D1660 InkJet Printer
My doesn't print and i had noticed that there is an deleting error in an document
  • 86 Answers
Reboot your computer. Keep canceling and deleting the document. It usually takes a little time for it to sync with the printer, but it will eventually go away.
Posted on Mar 12, 2011
Wireless printing doesn't work
Is the printer set as default in the printers? I need more info to give a solution. Is the printer offline? Try to delete the printer and re-add in software. What message do you get when you try to print to printer? Are your documents in Que to be printed? If so Delete /cancel and try to print again.
Nov 02, 2012 | Acer Aspire One PC Notebook
My HP laser jet M1120 MFP is repors error message when printing
Re install the tonner and then go to Printer & Faxes settings and delete the all kinds of pending documents and the go to print a new document and after taht send me the result...........what is happening.
Oct 01, 2012 | HP LaserJet M1120 MFP All-In-One Printer
As soon as you turn on my printer it already wants to print what i have printed previously how do i stop that from happening
You need to clear the print queue from the (any) workstation that is printing to it.
  • go to Control Panel/Printers
  • Open the printer in question
  • highlight any documents awaiting print
  • press 'delete'
The documents may not all completely delete until the printer is turned back on.
If this doesn't fix it then please reply before rating this answer as I can detail a manual method of clearing the queue, but I recommend using the above process first.
Please take the time to rate this answer.
Many Thanks Don.
Sep 05, 2011 | HP DeskJet 932c InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
Deleting-S error HELP
Try to stop and restart the print spooler (right click on My Computer and then select Manage. At the bottom of the Computer Management window, expand Services and Applications. Click on Services, and on the right side of the window look for Print Spooler. Right click on it and select restart). Even if this procedure does not fix your OADP file problem, consider it in the future and avoid restarting the computer every time you want to get rid of spooling printing documents.
Jul 25, 2007 | HP DeskJet 1280 InkJet Printer
HP D1660 InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
