Question about Kitchen Ranges
I need to replace a bulb in my blanco cooker hood. but can't open the glass cover
bigg t
  • 640 Answers
SOURCE: broken glass light cover...
you should be able to use the unit without a problem,in between the panels where the light is theres insulation.you can try northernparts.com they may have a replacement cover for your unit.
Posted on Dec 26, 2007
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
SOURCE: indesit cooker hood
HELP WHERE IS THE FUSE
Posted on Mar 11, 2008
zeusfaber
  • 247 Answers
SOURCE: When trying to replace my
Wouldn't expect a fuse to be the problem with those symptoms.
You need to fish out the old bulbs (that is, the last ones you had that worked for any period of time) and read the ratings off them. You are particularly interested in a number followed by a capital V (so this might be 12V, 120V, 230V or any of a number of others). This is the supply voltage they are are compatible with.
You need to be sure you buy replacements which have the same voltage rating. If your replacements are rated for a lower voltage, they will expire in a blaze of glory the instant you apply power. If they're rated for a higher voltage, they'll glow very dim and yellow.
You have a little more leeway withthe wattage rating (a number followed by a W, eg 15W, 25W). It's safe to go lower (though less bright), and probably OK to go a tiny bit higher but if you go much further than the enclosure is designed for, you risk problems with overheating.
If you're certain you have the right bulbs but the problem hasn't gone away, you'll need to come back with more information. It might help to know: Brand & model of the hood in question, what rating (both V and W) the bulbs are, how long they last, what it looks like when they blow (bright white light, or brilliant blue flash), what it says on the rating plate of the hood, and what part of the world you live in (tells us what the power supply is like).
But my first guess would still be that the new bulbs are the wrong type.
A.
Posted on Nov 15, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Fix Bulb Holder in Cooker Hood
please see the video attached, and fix it. GOd bless you
Nov 20, 2013 | Kitchen Ranges
Unable to open light on Kukoo cooker hood to replace halogen bulb
You have to just force a flat head screwdriver in the gap (the inner gap) and pry out the cover.
Like this: http://www.youtube.com/watch?v=ssTCGPj9CWY
The kukoo isn't as obvious, but it's the same.
Jan 29, 2012 | Kitchen Ranges
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
I have a necht cooker hood and need to replace a bulb, how do i do this as there doesn't seem to be a way of getting to the bulb?
Hi there, the inner ring that is holding the glass where there are tiny little holes all round. Put a screwdriver on there (not through the hole) and prise it open. It should come off.
Feb 13, 2010 | Kitchen Ranges
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Baumatic cooker hood lights not working
    Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
    Belling cooker hood chim101 BL - light/ lamp
    I just had this very same problem and believe I have solved it!
    You can remove the entire light unit from the hood. On first inspection it appears to be a sealed unit that does not allow you to remove either the wires or what looks to be a regular halogen bulb. If you turn the unit so the bulb is facing you, you can gently prise the glass from it's housing leaving the naked halogen bulb exposed beneath it. You can gently pull this from the housing and buy a new one to replace it. I would advise that when installing the new one you make sure it is completely free from any contaminant as any grease etc can greatly reduce the life of the bulb. Hope this helps!
    Nov 04, 2008 | Kitchen Ranges
    Neff cooker model b1422nogb bulb replace
    Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
    Apr 28, 2008 | Neff B1421 Electric Single Oven
    Indesit cooker hood
    indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
    Oct 17, 2007 | Kitchen Ranges
    Kitchen Ranges Logo
    429 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
