Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have a fisher & paykel intuitive eco and on the display screen it reads needs a service code 37 ?
  • 55 Answers
Hello, It sounds like you have a restricted or blocked drain pump. This usually occurs in the outlet of the pump between the pump and the diverter valve. 1st check that the drain hose is not kinked or crushed and does not have too long of an extension on it. If the tub did not drain you will have to bail or otherwise remove the water. Of course unplug the machine before any service. Once that is done, lean the machine backward the drain pump is located under the machine on the right side close to you. unplug the wires to the pump and remove the pump by lifting the small plastic catch and turning the pump assembly a quarter turn counterclockwise. Next disconnect the pump from the hose to the diverter valve. you can also remove the pump hose from the diverter valve and check to see if anything is caught in the valve. That's really all there is to the drain system. Good Luck.
Posted on Mar 12, 2011
Fisher paykel error code 37
check drain pump is not blocked or faulty
Aug 03, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
What does the rotary position sensor look like on a fisher and pykle intuitive eco washer
under the motor cover there is a small electronic board attached to the motor, thats it
Jun 30, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
We have a fisher and paykel intuitive eco, which says code 37,
Hi just read your posting.Now ERROR CODE 37 means PUMP BLOCK ERROR.Is your machine draining any of the water out of it?Please reply with additional information on the question and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel Washing Machines
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 37 F & P Eco IWL16- still pumping slowly
Cleared out the diverter valve (full of lint) then the machine started pumping properly.
Aug 15, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Screen has code 37 on it
Hi, welcome!
Code 37 is a "pump blocked error" code. Typically this code is triggered when the machine does not sense a change in the water level when called for. Check for debris caught in the pump, either in the impeller for moving water or in some cases, the external cooling fan impeller (exposed underneath the machine) gets snagged with a piece of fabric softener sheet (such as "bounce") and this will stall the pump and trigger a code 37.
I hope you find this info useful and thanks for using Fixya.
Jan 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive error code 37
Dear chopper667,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the washer and then rebooting it after 3 minutes!
If this fails,
here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Aug 26, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
101 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
